Home Forums Sign Making Discussions Vinyl can vinyl be applyed to shotgun barrel?
  • can vinyl be applyed to shotgun barrel?
    Posted by Roy Roberts on 9 October 2006 at 16:04
    Can anyone suggest what vinyl would be best to use,
    Customer wants to put his sponsor on the barrels.
    Many Thanks
    Roy.
    Gordon Forbes replied 19 years, 1 month ago 6 Members · 9 Replies
  • 9 Replies
    9 October 2006 at 17:01
    any cast should do the trick….. warm the barrel with a heat gun after you have it applied. if it doesnt stick well first go, remove it and warm the barrel "before" applying the vinyl.
  • Roy Roberts
    9 October 2006 at 17:31
    Many thanks for the help Rob.
    Roy.
  • Derek Heron
    9 October 2006 at 18:40
    The dangerous brothers 😮
    you hold it, ile heat it, is it loaded,
    just had a fright with a firework rocket never mind a shotgun.
    be carefull out there
    Derek
  • Roy Roberts
    10 October 2006 at 05:25
    Thanks for the advice Derek,
    Had a slight accident 2 weeks ago, went to spec-savers had eye test new glasses, got home late and had some signage to fit and customers to see.
    As there was only one 4ft x 2ft sign in alubond and a round steel 18" disc I put them under my arm with paperwork in the other and proceeded to step over my 2ft wall (which i have done for the past 20 years) my foot caught the top of the wall and over I went. The next thing I knew the the steel disc was bent I had a lump out of my chin, arm & knee grazed and a mark across my throat.
    After 2 hours in the doctors surgery and a bit of a lecture decided to walk round the path to van in future.
    Took a day before it hit me how lucky I was.
    Roy.
  • Checkers
    10 October 2006 at 12:53
    Hiya Roy,
    Vinyl on a gun stock won’t last long if your client uses it for anything other than show. I would definitely suggest paint.
    If you need some ideas, check out this site…
    http://www.indocilart.net/flash.html
    and look under corporate & special projects
    I’m sure you easterners will love it 🙄
    Checkers
    a.k.a. Brian Born
    Harrisburg, PA USA
  • Cheryl Tissington
    10 October 2006 at 13:27
    quote Robert Lambie:
    any cast should do the trick….. warm the barrel with a heat gun after you have it applied. if it doesnt stick well first go, remove it and warm the barrel “before” applying the vinyl.
    Robert,
    I don’t think the owner would appreciate you heating the barrel with a heat gun. 😮 :yikes:
    Cheryl 🙂
  • Gordon Forbes
    10 October 2006 at 21:59
    I wouldn’t think it would do them any harm
    You do 30 birds DLT and touch the barrels then seen them almost too hot to touch.
    Goop
  • Cheryl Tissington
    10 October 2006 at 22:11
    Goop,
    the heat produced inside a rifle barrel is slightly different to using a heat gun on one side of it.
    Any international rifle shooter would run a mile if you offered to heat their individually bored and highly accurate bench tested barrel.
    Cheryl
  • Gordon Forbes
    11 October 2006 at 01:40
    I’ll shut up and not do me Styer CISM 300m target rifle or me Remington PSS in 5.56 nor my SSG Speedmaster in 5.56 neither the Tikka in Rem 22/250. plus I have a few others but I won’t bore you with any more details.
    Goop
