Home Forums Software Discussions Adobe Software can vectors be saved in photoshop please?
  • can vectors be saved in photoshop please?
    Posted by Gary Davis on 12 November 2004 at 15:09
    I have a customer that has there logo in photoshop, am i right in thinking photoshop can save graphics in a vector format as well as jpgs giffs etc?
    if so what format is it ?
    any advice appreciated, basically need a file out of photoshop in a cuttable format
    image replied 21 years, 1 month ago 6 Members · 14 Replies
  • 14 Replies
  • Rodney Gold
    12 November 2004 at 15:21
    Only the later versions of PS do both vector and Raster, I thnk PS7 , PS elements and CS. You can export or save as an EPS.
  • Signs & Wonders
    12 November 2004 at 15:41
    I have Photoshop v7. Just tried saving as ‘Photoshop.eps’ on my Mac, e-mailed to my PC. Cutting program recognised it and cut it. Saved it with background though, maybe needs to be on transparent background in Photoshop.
    Other way is to send .jpeg to Vectorwise.
    Tony
  • Gary Davis
    12 November 2004 at 15:54
    thanks folks,
    so could you open a jpeg in photoshop and export it as eps and thus vectorise it?
    or have you got to start with a .ps?
  • Signs & Wonders
    12 November 2004 at 16:08
    Just opened a .jpeg, saved as photoshop eps and sent to cutting software. I couldn’t open this one – file format not supported. Maybe I’m not doing that one right. Could be too much information/colours etc. The first one I tried was a photoshop file that I converted.
    Do you have Corel Draw? You might be able to do what you want in Corel Tace…
    Tony
  • Gary Davis
    12 November 2004 at 16:14
    ahh brilliant idea tony!!! forgot i had that!!
    do you have any ideas on my other post re: getting vector files from.pdf’s?
  • Dale Horn
    12 November 2004 at 16:19
    How about exporting paths to Illustrator ? 😀
  • Gary Davis
    12 November 2004 at 16:21
    havent got illustrator!
    tony have just tryed corel trace, however i copied the logo from a .pdf (capture) and it looks pixelated the trace is also pixelated!
    the logo in the pdf looks fine even at 800% any ideas how i can get it out of the pdf at a higher resolution?
  • Signs & Wonders
    12 November 2004 at 16:33
    I’ve just Imported a .pdf into Corel Draw, Then Converted to Bitmap. Maybe you can then tidy up the piece you want, then Trace in Corel Trace…Best I can come up with on a friday afternoon – it’s getting dark and my brains slowing down…..
    Hope This helps
    Tony
  • Gary Davis
    12 November 2004 at 16:34
    cheers tony will keep trying with corel for some reason keeps crashing when trying to import pdf!!
    thanks for all the advice
  • Signs & Wonders
    12 November 2004 at 16:50
    If you want to e-mail me the .pdf with a few instructions of what you want, I could see if I can open it. Can’t promise anything, but two heads are better than one.
    Tony
  • Gary Davis
    12 November 2004 at 16:57
    cheers tony may take you up on that, gonna try a few other options first, seems my version of corel is playin up it wont import files without crashing for some strange reason!
  • Dale Horn
    12 November 2004 at 16:59
    Why not export paths to illustrator and import into Corel ?
  • Andy Gorman
    12 November 2004 at 17:06
    If you are having problems with corel crashing, try rebooting. If that doesn’t help you may have to re-install. I’ve had this happen a few times and coudn’t get it to work without re-installing.
  • image
    13 November 2004 at 05:44
    dtg:
    when corel(9) imports pdf-s, you can choose the import filter:
    – PDF Placeable Enhanced PDF Page – this makes a rasterized, low res. graphic
    – PDF Adobe Portable Document Data – use this filter, if you want vector graphics (only if the pdf contains the logo in vector format)
    Other question: can Photoshop 7 import illustrator files (or eps, etc) as a clipping path or as a vector shape?
