Home Forums Printing Discussions Uniform Printers Can’t find IP Address
  • Can’t find IP Address
    Posted by David Graves on 12 November 2010 at 12:07
    Hi guys,
    So i have moved premises this week, got all my equipment across and set up, and get an urgent order to finish by Monday. My grenadier printer is ready to go but when i try and print the PC tells me that it can’t find an IP address? I dont have an internet connection until my cabling is completed on Monday and I usually run the printer through a router, so I am attempting to run the LAN cable straight from the PC to the printer. Is this possible as my networking understanding is not great? If it is can anyone suggest the reason for not recognising the IP address.
    Any help would be great, thanks.
    David Graves replied 15 years, 1 month ago 6 Members · 9 Replies
  • 9 Replies
    12 November 2010 at 12:21
    sounds like DHCP was in charge by the router assigning your main PC’s… reconnect it up how it was and it should be fine.
    That means leaving the router on without the internet.
  • David Graves
    12 November 2010 at 15:43
    Cheers Dave,
    I have tried connecting through the router as it was previously but still keep getting the same message whenever i try and print.
    ‘failed to open TCP/IP’
    TCP/IP: 192.168.1.101:9100. Any other ideas?
    12 November 2010 at 16:00
    if you google "192.168.1.101:9100" you will find this is a common printer problem discussed on a number of forums. I think your problem is explained in some of the replies given.
  • Tim Painter
    12 November 2010 at 16:04
    Maybe check IP address?
    This is on another post from here.
    Turn on printer, press menu, press up arrow 5 times, press 1 right, 3 down, 1 right and 1 right and there is your IP address.
  • Johnny Alston
    13 November 2010 at 23:57
    duplicate
  • Johnny Alston
    13 November 2010 at 23:58
    go into your original discs and look for the program intercon net tool.
    You probably still have it installed on the rip pc to be honest this allows you to access the ip and change the ip on the machine.
    Had the same problem couple of weeks back.
    Helpful advice on here helped me solve the problem.
    14 November 2010 at 00:08
    at the end of every socket is a light, normally starts flickering when you put it in… i gonna presume its all good.
  • Martin Grimmer
    15 November 2010 at 10:29
    David,
    Is it a possible firewall problem?
    Martin
  • David Graves
    15 November 2010 at 12:27
    Thanks for the advice guys. I eventually got to the bottom of the problem. Inter-Con Net Tool resolved the issue.
