Home Forums Software Discussions General Software Topics Can’t delete on PC
  • Can’t delete on PC
    Posted by Andrew Boyle on 16 August 2007 at 21:18
    I admit I don’t know my way around a PC…………but for some reason I can’t delete a lot of files it says "they’re being used by some……..".
    Even when I disconnect the ethernet cables etc I still can’t delete them.
    I’ve had a few people that know PC’s better than but they don’t know how to delete them…..I’m having to use software called Dr Delete to get rid of them on re-start.
    Any help appreciated 😀
    David Rowland replied 18 years, 3 months ago 10 Members · 15 Replies
  • 15 Replies
    16 August 2007 at 21:24
    not sure if i have this right but only time i get that mate is if another program has the file open at the same time. i.e. you open a picture in photoshop. then in windows explorer try and delete it… because its open in photoshop it will deny you the right and say its being used.
    answer is to close all programs that may share the file. go to windows explorer and delete the file there. quick keys to windows explorer is hold "start/windows picture key" then press the letter "E".
    Im probably wrong on your problem but thought ide mention it… :lol1:
    16 August 2007 at 21:26
    What sort of files Andrew?
  • Andrew Boyle
    16 August 2007 at 21:27
    They’re all ai, pdf and eps files.
    Even on a clean restart not connected to anything, nothing in the ports etc………no applications open. I still can’t delete 😕
    Appreciate it 😀
    16 August 2007 at 21:30
    unlocker does it andrew….give me two mins and i’ll find it for you 😉
    16 August 2007 at 21:35
  • Andrew Boyle
    16 August 2007 at 21:40
    Great………..will give it a try……..it won’t let me delete about half the jobs I have on my desktop….any idea if there’s anything I can do to stop it happening in the first place? I don’t want to f about with it too much it’s used mainly for the RIP and large’ish files 😀
    16 August 2007 at 21:43
    quote Peter Normington:
    yes it is peter..thanks saved me looking for it on another machine 😉
  • John Singh
    17 August 2007 at 08:56
    I can’t believe I’m trying to do the same bloomin’ thing at this very moment
    Two stubborn corrupted ai files sent to me
    Can’t shift them from the recycle bin which means painstakingly removing each file
    Will try this
    Thanks Peter and Nik
  • John Singh
    17 August 2007 at 09:44
    Well just tried it
    It worked!!!!
    Absolutely brilliant and saved me loads of time and frustration as I seemed to have thousands of piccys needing to be deleted
    Thanks to the crew
  • Alan Cooper
    17 August 2007 at 12:23
    I’ve had almost 300mb in my recycle bin for weeks that I couldn’t delete.Just downloaded this software and they’ve all been deleted-fantastic
    Alan
  • Andrew Boyle
    17 August 2007 at 18:27
    Worked a treat and simple 😀 Thanks
  • Brian Little
    17 August 2007 at 18:37
    try this folks … ilove it http://www.ccleaner.com
  • Gordon Forbes
    17 August 2007 at 23:17
    start in safe mode and delete em
  • Derek Heron
    22 August 2007 at 19:05
    thanks for the link guys this has been doing my head in for ages trying to get rid of stuff from My desk top.
    the pc in question is by itself not connected to tinternet as it runs the cadet , just loaded advanced windows care onto it as it has been having problems on start up i was having to re boot etc to get going .
    now touch wood starts up n o problem and quicker
    Derek
    22 August 2007 at 22:35
    remember when deleting JPG’s and your using the thumbnail or picture view, the damn thing tries to create index thumbnails so it prevents you from deleting files in explorer, normally after 10second you can delete them.
    Ok ur sorted… if your on network, permissions can be one reason why you cant delete..
