Home Forums Software Discussions Flexi Sign Software Can’t contour cut with FlexiPRINT & CUT 8.6v2 & Rola
  • Can’t contour cut with FlexiPRINT & CUT 8.6v2 & Rola
    Posted by Mark Klein on 18 May 2010 at 01:30
    No matter what I try, I cannot get it to work. When I go to the Help Topics, I find nothing that works. It talks about a ‘Contour’ button under the Advanced tab, but there isn’t one. I just got the software today……brand new……..what am I doing wrong?
    Thanks,
    Mark
    Mark Klein replied 15 years, 6 months ago 2 Members · 2 Replies
  • RayRosher
    18 May 2010 at 13:49
    Maybe consider getting the Mark Rugen tutorial DVD As i found that an Invaluable aid to getting to know flexi.
    And a bit more information would help
    IE computer setup, cutter printer setup,
    Do you have a print and cut machine or are you using more than one machine surprised SAI didn’t throw in a DVD or a tutorial of some sort.however you need to make sure that you have your cut print machine recognized by both your operating system and flexi
    in flexi you need to go to file
    then Rip & Print.
    this should then bring up a dialog box asking what cutter printer your using select you machine,
    you should then have a Rip & Print box open,
    go to advanced once you have setup your output settings etc you will see your contour button about half way down the page next to the Driver options tab, if this is grayed out then your not setup properly
    Sorry ran out of time have to go
    Re Ray:)
  • Mark Klein
    18 May 2010 at 13:54
    Hello,
    I figured it out late last night 😀
    Thanks for the reply though.
    Where would I find this Mark Rugen tutorial dvd? And how much is it? Sounds like something that would be very handy.
    Thanks,
    Mark
