Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Can someone please help me with my blade settings
  • Can someone please help me with my blade settings
    Posted by Dustin Hart on 26 December 2009 at 12:45
    I have a Creation PCUT PRO II 730mm Vinyl Cutter and am using flexistarter 8.5v2. I try and cut stickers which seem to be going ok. The problem I have is that the blade does not always finish the the line when moving on to the next image and i am left with a 1-2mm section that i have to manually cut when pulling the excess off. Any help would be greatly appreciated.
    John Thomson replied 15 years, 11 months ago 1 Member · 1 Reply
  • 1 Reply
  • John Thomson
    27 December 2009 at 09:54
    You will need to adjust you blade offest setting depending on the spec of blade you are using then adjust the overcut setting……normally you wiill use double the blade offset as a starting point.
    After a bit of messing around you should get setting that work well for your machine.
