Home › Forums › Sign Making Discussions › File Swapping › can someone open this file an resave for corel 12
Posted by Colin Bland on 28 July 2008 at 10:04Hi
was wondering if one of you kind people could open this file I need to use in corel 12 thanks in advance
Colin
Chris Windebank replied 17 years, 5 months ago 5 Members · 7 Replies -
ok so now this is fun cant get the file to attach
is a .ps
any clues? anyone
for your info, you have a Postscript file, these are generated by a print dialog when you specify that you want to output to ‘file’.
You should be able to open it in Corel with the Postscript option on Import, they sometimes are a bit complicated.
If you have a RIP/Printer setup, run it through the RIP and see what it is.
rename to.eps then import if you are having trouble, sometimes works
