Home Forums Sign Making Discussions Vinyl can someone advise me on fitting non-slip floor graphics?
  • can someone advise me on fitting non-slip floor graphics?
    Posted by Craig Hudson on 14 April 2008 at 17:45
    I’m running some floor graphics on my JV3, onto a Mactac vinyl and laminating with appropriate non-slip mactac product. They’re a fairly messy cut shape and there’s lots of them, so I planned on printing as a batch, overlaminating the whole roll, and then trimming on my CG160FX.
    BUT one of my freelance fitters has suggested that given that these are going in a busy traffic area (thousands daily) the overlaminate should extend beyond the image by about 10mm all round.
    To do that will turn the job from a relatively simple task into a long winded labour intensive hell, and I’d far rather stick to my original plan if it’s viable.
    Can someone who produces these regularly offer me some advice please?
    regards,
    Craig
    Stuart Taylor replied 17 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Mathew Gibson
    14 April 2008 at 18:19
    ive never tried these as yet but in my opinion i think your fitter is right!
  • Andrew Boyle
    14 April 2008 at 20:03
    Craig…..Most don’t seem to do the 10mm overlap anymore….I have done exactly as you described and not had a problem.
    You can still print, cut, laminate, cut [using the CG160FX]
  • Craig Hudson
    15 April 2008 at 00:11
    Andrew.
    Print, cut, laminate, cut… ??
    I’m trying to figure out how to do this. I can print the roll, cut the roll, weed the roll. Then laminate the roll… BUT in weeding I’ll have removed the registration marks, so how do I then cut the larger path to give the 10mm overlap?
    If these weren’t going in a theme park restaurant I’d probably do without the overlap, but he’s got me worried now that the high footfall could lift the edges. Then again, what’s to stop the edge of the 10mm lifting anyway!?
    Craig
  • Gordon Forbes
    15 April 2008 at 04:11
    You can weed without removing the registration marks.
  • Steve McAdie
    15 April 2008 at 13:44
    Hi Craig,
    You print first, then remove to laminate, then reload to contour cut. Thats if your printer or cutter has optical eye for registration marks.
  • Steve McAdie
    15 April 2008 at 13:47
    If you wanted to cut a wider laminate try contour cutting around reg marks and leaving them on when you weed.
  • Craig Hudson
    15 April 2008 at 13:53
    going to try that now… unfortunately there are a lot of these so a relatively straightforward job is becoming a cow. Ah well.
    Thanks for all of the responses, much appreciated.
  • Stuart Taylor
    15 April 2008 at 14:30
    Sorry for the late response as only just seen your post
    The trick with floor graphics is to keep the outer shape as simple as possible – no fiddly bits as these will get kicked up and lift.
    I would not recommend having the laminate produced oversize as this could cause adhesive residue issues when removing (floor graphic base films should be removable adhesive but laminates should be permanent adhesive)
    Most manufacturers recommend smooth cuts to the outer shape (including radius corners on square graphics) this reduces the risk of edge lifting…….unfortunately not all end users or designers take this recommendation on board.
    Stuart
