Home Forums Sign Making Discussions Traditional can i use vinyl to mask lettering for applying to vehicle?
  • can i use vinyl to mask lettering for applying to vehicle?
    Posted by Dale22 on 17 April 2006 at 19:48
    Hi there could anyone tell me if its possible to get a decent result by having lettering cut on a plotter out of some sort of masking film, applying it to the vehicle & painting in the letters with One-Shot, sort of like stencilling…. im sorry if this doesnt quite make sense but be gentle as i am a novice… thanks
    Robert Berwick replied 19 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
    17 April 2006 at 20:03
    I have done this, as have many others.
    It’s not a bad job if you get the right mask.
    Now what that might be, I can’t say.
    I have had poor results with Cal-Mask by Arlon as well as mac mask by Mac-Tac.
    Good thing I’m pretty fair at hand-painting.
    17 April 2006 at 20:05
    I used a vinyl mask for a gold leaf job. The mask was Oracal Oramask, you can buy this from Europoint. Great stuff.
    Marcella
  • Dale22
    17 April 2006 at 20:09
    jill when u say poor results what do u mean…?
    17 April 2006 at 20:54
    I mean that the mask was horrible to weed & cut…stuck up under my fingernails etc.
    Took hours.
    Then I stuck it on and rolled it
    (this was a 4’x6′ job site sign with 1" Hellvetica contractor’s names…ugh)
    Tried to pull it up fast, it made a terrible mess.
    Let it dry & it was even worse, peeled off the fricking 1-Shot.
    Ended up re-painting the whole mess by hand.
    (I should have just made a pounce pattern and gone from there)
    That’s what I meant by bad results.
    Supposedly Gerber makes a good mask.
    I have had better luck using calandered vinyl.
    And even better results by just painting the traditional way. 😉
    17 April 2006 at 21:06
    Most makers of Vinyl do a paint mask, I have used it on glass and panels without a problem, just let the paint dry fully, before lifting the mask. (Cant vouch for one shot though, as I have never used it) I will be off to the trossachs next month to see how the real pro’s do it!
    17 April 2006 at 21:16
    i tend to lift the mask after about ten mins of painting…if i let it dry i get a ridge of paint round the lettering, which is unsightly especially if the lettering is fairly small, but then again i only use solvent inks to paint with 😀
  • Robert Berwick
    21 April 2006 at 18:59
    Hellvetica 🙂 – not your fave font then Jill?
