Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Can I use vinyl master pro with Pcut
  • Can I use vinyl master pro with Pcut
    Posted by Dustin Hart on 26 December 2009 at 13:08
    I have a Creation PCUT PRO II 730mm Vinyl Cutter and am using flexisign 8.5v2 , but I would like to use vinyl master pro . Is it possible and how do I link the vinyl master pro with the cutter?
    Ian Johnston replied 15 years, 10 months ago 2 Members · 2 Replies
  • Alan Wharton
    28 December 2009 at 20:58
    when you install vmp and go into setup there is a list of cutters if the pcuts not in there you can set vmp to a default hpgl cutter settings, theres a video on the disc that shows you exactly how to set your cutter up in the help section.
  • Ian Johnston
    28 December 2009 at 22:17
    quote Dustin Hart:
    £1000 software with £200 cutter ?
