Home Forums Sign Making Discussions Neon, LED, Lighting can i use 3m tape instead of tracks and clips?
  • can i use 3m tape instead of tracks and clips?
    Posted by Brian Little on 18 September 2007 at 14:04
    hi folks ive got a dibond board to place under an existing roadside sign..its going on with tracks and clips …..not a great deal of experience of using tracks and clips i have to be honest .Iits only 8ftx2ft board so its not going to be heavy .Question ….would i get away with putting 3m double sided …or equal quality tape along the track or do i have to screw holes in the facing which i dont really want to do
    Regards Brian
    Brian Little replied 18 years, 3 months ago 4 Members · 6 Replies
    18 September 2007 at 14:08
    Brian, where is it going? VHB tape if applied properly will do the job but if it is on the public highway it will need to be riveted as well I believe.
    If you are floodcoating the whole panel you can drill and use countersunk rivets so when you cover there are no rivet heads showing.
  • Brian Little
    18 September 2007 at 14:17
    hmm its at low leval martin ….its to go under an existing hotel sign .When i said road sign i didnt actually mean coucil/roads department although its just off the road .Im not fload coating …its just white with reflective blue lettering
  • Andy Gorman
    18 September 2007 at 14:43
    I’ve done it with VHB before on smallish signs, like 4′ x 3′. If you are flooding the panel white then you could use some countersunk fixings but they’ll still show a little bit through the vinyl.
  • Brian Little
    18 September 2007 at 14:58
    cheers andy .as i said im not flood coating just blue lettering on it .I might be lucky a lot of the lettering might hide the screws
  • David Rogers
    18 September 2007 at 19:17
    Brian, I’d use d/s tape and rivets. (Like that job you helped me out on)
    Whilst properly applied VHB tape WILL do the job, and the surface will be perfect – I’d only trust it at this size & location if you were doing three rails and it is a paint to paint application not raw metal and I’d certainly be using adhesion promoters to be VERY sure of the bond.
    From a ‘normal’ viewing distance, 4 or 5 rivets through the front are barely noticeable and can be just an integral part of the sign.
    Belt ‘n’ braces…
  • Brian Little
    18 September 2007 at 22:27
    cheers dave ….its only about 2ft off the ground in reality so ill take your advice
    regards Brian
