Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Can i run a troughlight from solar power?
Posted by Martin Manley on 4 October 2011 at 08:52I’ve just moved premises and have a sign about 100 metres from my workshop with no power supply anywhere near. Is it possible to rig up an LED or fluorescent trough light using a solar panel like the ones you see at country bus stops?
len heffer replied 14 years, 2 months ago 6 Members · 8 Replies -
I used insight sign systems based in glasgow and use their "super bright" LED trough lights. however, i am unsure if they offer a solor panel powered option.
http://www.insightsignsystems.com/you may want to speak to signscape who DO offer solar panel sign lighting solutions, but im not sure if a trough light is one of them.
http://www.sign-making-supplies.co.uk/i would suggest looking on the UKSB Sign Toolbar also as there are alternative suppliers on there.
http://www.uksignboards.com/viewtopic.php?t=38498 -
Solar power has always been…. dim.. when i looked at it
Problem is – at night time when you want to switch the light on there is no sunlight to power the solar panel 😕
quote Phill Fenton:Problem is – at night time when you want to switch the light on there is no sunlight to power the solar panel 😕
Solar panel > Charges 12 V battery ( Google 12V solar battery Charger) > timer > Lights on / Off on a 12V ( not 24 as most Trough lights are) LED light.
Simples 😀
Sounds good Ian but the whole solar power thing (special LEDs, chargers, solar kit) all works out really expensive – anyone got any other ideas for lighting this thing? Battery powered lights for instance?
Martin -
How big is your sign ? I Have a solar LED light unit that uses 5 LEDs but it is fairly small 180mm length – quite bright thou with dawn to dusk sensor around £20
Len
Len
Sign is 915mm wide by 1800mm. if I had a troughlight that washed down even half of it I’d be happy. If i could get one for £20 quid I’d be even happier!!!Please post details of your light….
CheersMartin 😛
Sorry mate mine is a little small….so all the ladies say 🙂 !
len
