Home Forums Software Discussions Adobe Software can I print selected objects in illy?
    30 March 2011 at 13:11
    sorted, I used the crop tool. is that the proper way its normally done?
  • Paul Jewell
    30 March 2011 at 15:03
    If you are using layers – turn off visibility of unprinted layers and in print choose ‘only visible layers’, will this work for you?
    1 April 2011 at 09:50
    Thanks for the reply, I also found that In the print set up I can select artwork boundary, which does what I want, (almost)
    I use signlab most of the time, and I can just print "selected object"
    I thought maybe Illustrator had a similar way to do it.
