Home Forums Printing Discussions General Printing Topics Can I print onto ordinary vinyl ?
  • Can I print onto ordinary vinyl ?
    Posted by Cheryl Tissington on 21 May 2007 at 11:50
    is it ok for me to print images onto ordinary cream vinyl.
    I’ve got 2 images from istock that my client wants on a very large shop sign.
    She wants the main background colour to be cream.
    The images do not have transparent backgrounds, they are white and are quite fiddly to alter.
    Instead of printing the whole sign with a cream background, I want to know if I can print the images straight onto cream vinyl.
    The white background wont show – it will show as cream.
    My question is, will the ink be ok on the vinyl and stand up to the weather etc.
    Any help really appreciated.
    Cheers,
    Cheryl 🙂
    Shane Drew replied 18 years, 7 months ago 12 Members · 22 Replies
  • 22 Replies
  • Gavin MacMillan
    21 May 2007 at 11:59
    The main issue will be the cream altering the colours of you images. Everything will take on a darker or cream tint and possibly not look right. Others will be better qualified to answer the durability question but as understand it, there would be no real difference.
    G
  • Cheryl Tissington
    21 May 2007 at 12:04
    Thanks Gavin,
    the colour should be reasonably ok.
    My main concern is the durability of the print.
    Cheers,
    Cheryl
  • George Elsmore
    21 May 2007 at 12:05
    Why not laminate after if its a durability issue?
    G
  • Cheryl Tissington
    21 May 2007 at 12:13
    Cheers George,
    I’ll frog juice the image when its completely dry.
    All the best,
    C x 😀
  • Alistair Richards
    21 May 2007 at 15:47
    what wbout printing onto clear, then laying onto cream background.
    21 May 2007 at 15:51
    is this image full colour or just gray scale/black and white?
    are you printing using a solvent printer or thermal?
  • Cheryl Tissington
    21 May 2007 at 20:20
    Hi there,
    Rob the image is full colour and I’m using a versacamm with eco inks.
    As it happens, I printed the graphics onto cream vinyl this afternoon. The image has come out well and I’m pleased with it.
    I’ll give the printed area a quick misting of frog juice tomorrow.
    Cheers,
    Cheryl 😀
  • Joe McNamara
    21 May 2007 at 20:51
    Hi Cheryl,
    I print loads of black onto yellow vinyl then ezytaper it onto magnetic for taxi signs.
    It prints fine but you might need to try a few profiles to get a good one.
    The yellow I printed onto was oracal 651 and got through a full roll in a day.
    Seen some of the signs recently and they still look good.
    Joe
    21 May 2007 at 20:56
    Joe what printer do you have ?? I have been thinking the same thing recently, we do taxi’s black on yellow on to mag’s, is seem more time effective to print it, than cut weed and flood coat yellow, app, and apply 🙄
  • Joe McNamara
    21 May 2007 at 20:59
    Versacamm, Lynn.
    Your JV3 should be fine as well though.
    Just a matter of playing wit a profile that works well.
    I use the metamark MD5 profile for lots of stuff like this as it seems to work on really well
    Joe
    21 May 2007 at 21:36
    have to try that thanks Joe, you sort of get the impression though that you can’t print onto coloured vinyl as digi comes in white, no one says it you just assume, obviously wrongly. 🙄
  • Karl Williams
    21 May 2007 at 21:43
    I print onto Mactac 8300 all the time. Haven’t had any real issues. I found the eco inks from the Rocky 38 were crap, but the jv3 works fine.
  • Adam Triggs
    21 May 2007 at 22:00
    Hi Karl,
    Would you over laminate the 8300 as well, if so what would you typically use ?
    Adam
    21 May 2007 at 22:06
    I print on Silver, Chrome, Grey and Yellow all the time too.
    Only found two consistent issues:
    1st) It will give a better result on cal than cast. Cal can be printed off a roll out of the box, but oracal 851 for instance, needs to be cleaned with IPA otherwise it seems to reject the ink sometimes (like a silicon effect).
    2nd) Printing a long run will (I print 3 metre lengths on gray) will sometimes have the issue of a fine silicon line across the print giving a lighter colour shift. This happens consistently on the oracal 551 at about the 2 metre mark from my experience. Ive never had it happen on yellow 551 tho. I took this up with the manufactures, and they say that it is not warranted against printing because it is not ‘treated’ to be printed, so they can not guarantee that silicon may not be found on the surface.
    They can offer this guarantee on the digi print media though.
    I would laminate it tho
    Hope that helps
  • Ian Bingham
    21 May 2007 at 22:11
    have printed on to hexis banner vinyl no problems
    eco solvet ink
  • Adam Triggs
    21 May 2007 at 22:15
    Cheers Shane
    I’ll give it a go.
  • Gordon Forbes
    22 May 2007 at 00:30
    Skip the frog juice and get proper laminate The Oracal stuff is good 290 bout £4 a meter and apply wet for ease of applying no silvering as a result.
    just my tuppence
    tried all the other ways and proper laminate is the easiest and best way to go.
    Goop
    22 May 2007 at 00:56
    quote Forbie:
    just my tuppence
    Goop
    I agree with that too. 290 is very expensive here, I use oracal 215 for my day to day, 290 for vehicle wraps only
  • Karl Williams
    22 May 2007 at 09:50
    Hi Adam,
    If im doing labels I don’t bother laminating. If it’s a van with flat sides then i’ll just use 8300 clear. Sounds cheap I know, but it works and stops the image from getting scratched. It keeps the costs down, client’s happy and as of yet no complaints. 😀
    22 May 2007 at 10:53
    quote KARL WILLIAMS:
    Hi Adam,
    only problem with that Karl, is that it does not have much UV protection.
    Dedicated laminate is a bit dearer, but the print will last heaps longer, so the cost is probably cheaper over the life of the graphic.
    Yellow and red need all the help they can get, to prevent UV fade.
  • Karl Williams
    22 May 2007 at 11:04
    I agree Shane. When the customer places the order I ask them how long they’ll keep the vehicle. Most say around a couple of years so really not much can happen in that time. The first vans I did doing it this way nearly 19 months ago haven’t had any problems. It also depends on what their budget is as well.
    If anything needs a laminate I usually by it from ADS in Nottingham.
    22 May 2007 at 12:55
    Things fade much quicker here Karl, but I guess as australia has one of the highest UV rates in the world (and the worlds worst skin cancer numbers anywhere in the world) our fade problems are going to be the worst in the world too.
    Obviously not a problem there like we have here.
