Home Forums Printing Discussions General Printing Topics Can I print on this…
  • Can I print on this…
    Posted by Mike Grant on 17 August 2005 at 22:36
    I have a small job of stickers to print. The customer wants it printed on window cling vinyl. Now my question is this……I have a roll of standard window cling from Hexis and want to avoid having to purchase another roll for the VersaCamm for such a small job. Can I print using ecosol inks to the standard vinyl and if so what would the best profile be. (?) (?) (?) (?)
    Peter Shaw replied 20 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Mark Shipley
    17 August 2005 at 23:20
    Hi Mike,
    I print onto Hexis Static Cling with a VersaCAMM.
    A good profile that works for me is:
    Hexis Micro 2 profile (one way vision film) @ 720dpi
    Bi Dir
    Variable Dry
    1
    16
    500
    0.0
    Heater 35-45
    You may want to go to Variable for a more saturated colour.
    The main problem is puckering at the roll edge, you may need to use the long media clamps, but only put them part way onto the static cling otherwise they snag and bind on it.
    Hope this helps.
    Mark
  • Barry
    18 August 2005 at 07:17
    Its nice to know the Hexis cling is printable. Most all of the static clings have to many plastisiers(sp) in them to print well.
  • Stephen Morriss
    18 August 2005 at 13:01
    Hi Mark
    Do you print onto clear and if so what sort of colour saturation do you get.
    I tried with the Cadet onto clear and it was no good as the colours were really thin (maybe wrong word) so looked washed out on a window.
    I’ll be getting some white soon which I presume is simular to white vinyl for the colour.
  • Barry
    18 August 2005 at 15:16
    Generally the Eco-Sol and Solvent inks are not really opaque, so they are quite transparent. Black is generally the most opaque. If your Rip supports it you can do an overprint that will darken the colors up a bit, but it will be no where near as opaque as a thermal machine.
    I generally outsource cling and clear vinyl to someone with an edge as the results are much better than an inkjet can print.
  • Kate and Danny
    18 August 2005 at 15:33
    Hi, we were recently having pretty rubbish results using our versacamm to print onto metamark static cling.
    The colours were all acceptable but the black was not. This is how we made the black really bold and opaque, by letting the device ( versacamm) take control of printing the black.
    I went into the colorRIP
    PRINT > SETUP > EDIT > SPECIAL COLORS > Add Indexed Colors
    ( the colours from your image should be added )
    THEN I DOUBLE CLICKED ON > CMYK:0,0,0,255
    and clicked > Device ( bypass colour management )
    Then Save that profile and print!
    It’s surprising how, if you get the black right, the rest looks much better.
    We then laminated with standard white vinyl – and ran back through versacamm to cut… looked great. Didnt take any pics sorry….
    Danny
    18 August 2005 at 17:18
    we printed some on our JV3, it isn’t brialliant and we even print it and then flood coat white on the back isn’t that easy.
    Test run a sample and attach it to a window, see what you think before commiting as it isn’t as good as Silk Screen
  • Peter Shaw
    21 August 2005 at 03:13
    I’ve printed onto Hexis white cling film (standard stuff not digital) using my Cadet with perfect results. I found it was best to remove the media clamps completely.
