Home Forums Sign Making Discussions Computers – Tablets – Phones can i link together an imac to PC?
  • can i link together an imac to PC?
    Posted by magpie on 22 February 2005 at 13:02
    Any ideas as to the easiest, economical way to connect link my Imac and PC?
    Can they be linked via a USB connection or network cable?
    Cheers, Peter
    magpie replied 20 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bill Dewison
    22 February 2005 at 13:56
    Someone mentioned something about firewires, don’t know what they are, but it sounds good! 😀
    Cheers, Dewi
  • John Childs
    22 February 2005 at 14:05
    Assuming that your PC has ethernet, then a simple crossover cable should do the trick.
  • magpie
    22 February 2005 at 15:14
    Cheers, both.
    John do you know if any software be required to facilitate file transfer, say between windows xp pro and os9.2?
  • John Childs
    22 February 2005 at 15:21
    Shouldn’t be.
    Certainly I can connect to the rogue PC in our establishment from any of our Macs via ethernet with no problems. The PC should show up on your Mac desktop as just another volume.
  • jeffus – Graphtec
    22 February 2005 at 15:35
    Ethernet is a good common network connection, cross over cable if just the two computers as mentioned earlier, and a program like Dave or similar for sharing files and printers etc see link below
    http://www.macupdate.com/info.php/id/5026
    hope this helps
    Jeff
  • RobGF
    22 February 2005 at 15:49
    quote magpie:
    Cheers, Peter
    If you are using the ethernet route, you can also look at MacLan.
    http://www.miramar.com/Products/PC_MACLAN/
    MacLan will run on your PC and allow it to see stuff on an AppleTalk network. It will let the PC act as a server to the Mac, the PC to log into the Macintosh, and the PC to see devices set up on a Mac network. As our primary workstations here are Mac, we’ve setup MacLan on our PC’s (RIP’s) with great results. Haven’t used Dave but have heard good thigns about that too.
  • magpie
    23 February 2005 at 17:08
    Thanks all, am looking into these options now.
