Home Forums Sign Making Discussions Neon, LED, Lighting Can I buy ready made blank perspex or toughened glass?
  • Can I buy ready made blank perspex or toughened glass?
    Posted by Robert Scullion on 24 September 2006 at 13:23
    Can I buy ready made blanks, perspex or toughened glass, for wall mounted signage. The same idea as the ones on the main page that are on locators and sit off the wall on locators.
    Bob
    Andy Gorman replied 19 years, 2 months ago 4 Members · 5 Replies
  • Andy Gorman
    24 September 2006 at 13:28
    That would be handy. I do a fair few of these, the acrylic isn’t a problem as I get it cut to size but I have to take it down the road to get the edges polished.
    Most glazing companies will make you toughened panels, pre-drilled etc, but it takes a few days to get them made.
  • David Rogers
    24 September 2006 at 14:59
    If it’s thick stuff over 8mm+ I can buy cut to size & pre-polished from Stockline Plastics. (Dundee & Glasgow)
    Anything under that and I flame polish. (Quite a relaxing process).
    Toughened glass can be had edge polished, holes & rounded from a larger glass company (not normally your local domestic glazier). Not a cheap solution by any stretch of the imagination…
    24 September 2006 at 21:05
    i am honestly not a fan of using acrylic for these type of signs/displays.
    if i am going to do one i will always use glass unless stipulated. i feel you do not get the same finish/look with acrylic as you do glass. acrylic tends to scratch/mark far easier too…
    i prefer to use laminate glass when possible. its a little cheaper and thicker, so the polished edges look better. yes you can get thicker toughened but costs rise steep.
    you will have to Waite a few days for your panels from small glaziers as most just buy toughened/polished in from the bigger firms. i would contact companies like solaglass for your panels as they do everything "in house", so your cutting out the middle man. benefits are lower costing panels and faster turnaround.
  • Robert Scullion
    25 September 2006 at 07:52
    Thanks for the prompt replies, I was thinking along the same lines as Rob that the glass would be a nicer finish.
    When asking a glazier I assume you have to give them a template rather than stating something like 500mm x 200mm, small radius on corner and 10mm hole 25mm in from each corner.
    Thanks again peeps
    Bob
  • Andy Gorman
    25 September 2006 at 09:37
    I give measurements for cut glass, but if any holes etc are needed a scaled drawing with dimensions is a good idea. Glaziers can usually read a drawing! 😉
