Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters can anyone with driver for a graphtec FC4100-75 please?
  • can anyone with driver for a graphtec FC4100-75 please?
    Posted by Michael Stevenson on 27 October 2003 at 19:06
    just acquired s/h FC4100-75 loaded driver for XP Home,
    connected via LPT1 PORT set as default printer,settings all work on print command from corel draw, but plotter displays "error 1 instruction not recognised"
    any clues please!
    thanks mike
    Brian Hays replied 21 years, 12 months ago 3 Members · 5 Replies
  • Brian Hays
    27 October 2003 at 21:30
    The Graphtec can be set to GPGL or HPGL, I don’t cut using the windows Graphtec driver but it sounds like you may well be sending the wrong language to the cutter. Look at the cutter settings if it’s set to HPGL try GPGL & vice versa.
  • Michael Stevenson
    28 October 2003 at 16:47
    Thanks Brian
    spot on!! it was set on HPGL, but running on windows XP it does,nt seem to like Corel draw much, so I must invest in new software – but which one! Flexisign,? can,t afford Signlab,but lot of talk about VMP?
    any opinions????
    thanks again
    regards
    Mike
  • Tim Painter
    28 October 2003 at 17:04
    What version of Corel?
  • Michael Stevenson
    28 October 2003 at 21:33
    Hi Vivid
    corel draw 9
    over to you!
    regards
    Mike
  • Brian Hays
    29 October 2003 at 00:50
    Mike, I think you will find Signlab is a fair bit cheaper than Flexi.
