Home Forums Printing Discussions Uniform Printers can anyone tell me why the cutting path is out on grenadier?
  • can anyone tell me why the cutting path is out on grenadier?
    Posted by M Brown on 20 August 2008 at 19:45
    Hi All,
    I have a problem that I cant seam to fix. I have a 54" print and cut Grenadier. When I print and cut a job that requires a cut path very close to the image, the cut path is out of alignment and cuts into the image and leave lots of white space. It’s an image that I cant seam to put a good bleed on as its an awkward shape.
    My RIP is Wasatch v6. I have adjusted the Print & Cut through the menu on the Grenadier. The machine prints the test pattern and cuts a cut line on it. It was off line first of all, but I got it on centre. Its now spot on, but its still out when printing from the RIP. Is there a problem with the RIP or is there any setting that I can tinker with?
    Any help would be gratefully received.
    From Mark
    M Brown replied 17 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
    20 August 2008 at 20:14
    is the cut off with print and immediate cut or after lamination and fond the marks
  • M Brown
    20 August 2008 at 20:35
    it does it either if its cut straight after printing, or if crop marks are used. the printer finds the crop marks ok. i’ll phone b&p in the morning.
  • Kevin Flowers
    20 August 2008 at 20:40
    if we need to be very accurate on our print & cuts, i set a dry time in Versaworks to stop it cutting straight away. I then turn the heaters off the dry time normally 5 minutes gives the vinyl & machine time too cool, the cut is then spot on. I cut laminated prints with the heater off as well.
    20 August 2008 at 20:51
    quote :
    was this the L shaped grid with 2 cut lines.
    [/quote]
  • Russell Huffer
    20 August 2008 at 22:07
    Probably nothing to do with it but I have the 74" Grenadier that is print only and use Grahtec to cut. I had problem with cuts not in right place and it turned out to be because i had selected the "centre" optionn i uncheacked this and all was well again.
    Russell.
  • Kevin Flowers
    20 August 2008 at 22:13
    Russel
    thats a known fault with the RIP, Roland have a work around on their site although i think they only list it for Print & Cut machines
  • Russell Huffer
    21 August 2008 at 06:03
    Hi Kev,
    Unfortunatly like a lot of faults they are not readly advertised, i know about it now but i found out about it the hard way and as usual on a rush job, had a graphic going on the back of a van, printed it and left it over night to degas, came in next day laminated it and loaded it to cutter which cut it about 10mm off to one side, no time to reprint and degas another but was luckly able to trim the 1 side that still had white showing and use it.
    There is a simple work around, i now never use the centre option when cutting.
    Russell.
  • M Brown
    21 August 2008 at 06:36
    Hi Chris
    Yes it was the L shaped grid with 2 cut lines. The cut lines are right on line. I got to get this job cut today 😥 its bin drying all night ready for cutting. I was thinking of putting a key line round the image, but it looks rubbish like that. Plus the key line would still be un-even.
    From Mark
