Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters can anyone tell me why plotter bangs against side of machine
  • can anyone tell me why plotter bangs against side of machine
    Posted by Harry Cleary on 27 June 2007 at 10:36
    My cutter did something very odd this morning when I switched on, the head repeatably banged itself against the side of the machine before it went to its normal position, now when I send something to cut…it goes through all the cutting motions but the blade wont go down to the vinyl…..anybody any ideas?……sorry if this doesnt make sense but Im up the proverbial creek if I cant get it working.
    Its a Pcut 630….about 2 yrs old. Ive reinstalled everything and no joy! I cant afford to mess with it….is it dead?
    Martin Pearson replied 18 years, 5 months ago 6 Members · 13 Replies
  • 13 Replies
    27 June 2007 at 10:58
    Harry ……… check the carriage in case a screw has fallen out or become loose ……… could have happened as it hit the side.
  • Harry Cleary
    27 June 2007 at 11:02
    doesnt seem to anything missing or loose Marcella, and the blade is springing up and down if I press it. What worries me is that it bangs against the side everytime I switch it on.
    27 June 2007 at 11:11
    Harry, don’t know that much about plotters but it could be that it is looking for a sensor or limiter switch which is not working. Maybe trying to find a start position. Can you alter the settings so its head start position is to the left of the machine instead of the right?
    27 June 2007 at 11:20
    has the belt slipped?????? When it’s bumped the side could it have slipped off the belt slightly and that’s causing it to do it again?
    Or as Martin has suggested check and clean the sensors ……… a plotter won’t run if one of the sensors isn’t working.
  • Tim Painter
    27 June 2007 at 11:21
    Hi Harry
    I’m not familiar with the PCut but it sounds like it has no idea where it is on the carriage.
    I would check any optical sensors and any other sensors. Also it may have just had a mental and needs a factory reset, on many printers etc this is just a case of holding down 2 buttons and powering the unit on.
    I see http://www.signwizard.co.uk sell the units maybe they can help you.
    Sorry I can’t be of more help.
    Tim.
  • Tim Painter
    27 June 2007 at 11:37
    Only thing I could find on the Creation site – mainly in Engrish..lol
    6.18 Question: Why does the plotter is out of our control sometimes?
    Answer: Maybe while transporting or using it, the signal line is improperly connected, open the machine properly plug all lines. If the problem still fails to be solved after the above operation, please contact local agent or maintenance center 。
    Maybe worth unplugging and re plugging any connectors to double check them – maybe a poor connection.
    Teaching you to suck eggs Harry but make sure the machine is isolated from the power……….I don’t want to be responsible for a fried Irish man…lol
    Best of luck!!!.
    Tim.
  • John Childs
    27 June 2007 at 11:46
    Harry,
    I once had the same thing with an Aristo.
    In my case there was a little switch on the chassis of the cutter, which the carriage touched when it got to the end of it’s travel, so that it knew that that was as far as it could go.
    The little pin on that switch was stuck in, so the carriage kept trying to go further andbanging itself on the stop.
    A flick of the switch pin cured it.
  • Harry Cleary
    27 June 2007 at 11:51
    Tim, Martin Marcella, thanks for your help on this……no joy Martin with your suggestion, the carraige is still trying to leave the workshop on start up, Tim I’m going to try and take it apart and do what you posted……if its dead, its dead, I just need to know asap and try and get something sorted. Thanks everyone.
    George! unplug everything! there may be another surge!!! 😀 😀
  • Tim Painter
    28 June 2007 at 15:26
    Any joy Harry??
  • Harry Cleary
    28 June 2007 at 15:36
    Sorry Tim…should have updated this….the cutter was pronounced dead mid afternoon yesterday….have bought a Graphtec…should have it tomorrow morning!
    Thanks for all your help on this and everyone else who offered help and support!! 😀 😀
    Funeral for the PCut is tomorrow…..no flowers please…donations gratefully accepted!! :lol1:
  • Martin Cole
    28 June 2007 at 15:45
    quote Harry Cleary:
    :lol1: :lol1: :lol1:
    I won’t be able to attend Harry, so I’ll stick a postal order in the post.
  • Harry Cleary
    28 June 2007 at 15:47
    quote Martin Cole:
    quote Harry Cleary:
    Martin, you will miss all the dancing!!!……on the grave 👿 …. 😀 😀 😀
    28 June 2007 at 17:12
    Harry, unfortunately I won’t be able to make it either but I will be thinking about you both, I can’t dance anyway so I probably won’t be missing to much.
