Home Forums Vinyl Cutter Discussions Roland Cutters can anyone tell me why my PC60 wont pick up ribbons?
  • can anyone tell me why my PC60 wont pick up ribbons?
    Posted by Kev on 10 June 2004 at 21:11
    Just switched the pc60 on this morning and it refuses to pick up any ribbons, it was working fine Tuesday 😕
    The part (dont know what its called) that comes out to take the cartridge only comes out about half way and is making a horible grinding sort of noise 😮
    Tried moving the carts around and then tried new
    If anybody can help on this one ??? (all I seem to asking 😀 for)
    Bill Dewison replied 21 years, 6 months ago 8 Members · 21 Replies
  • 21 Replies
  • Bill Dewison
    10 June 2004 at 21:21
    Sounds like a serious problem 😕 🙁 It may be a mechanical fault of some description, or may be a sign the head has blown or something along those lines 🙁
    Cheers, Dewi
    10 June 2004 at 21:22
    quote :
    If anybody can help on this one ??? (all I seem to asking for)
    thats what the sites all about after all mate 😉
    regarding your problem. we had that happen to ours a while back. cant remember what we did to fix it as it was a while ago.. ill speak to andrew and ask if he knows.. im sure he will 😉
    11 June 2004 at 07:57
    The part that picks up the cartridge is a white screw like thread that aligns with the central top indentation and literaly “winds” the cartridge onto the head. Sometimes the alignment can go out and the “white screw” ends up off centre when trying to pick up the cartidge. You can see this happening. If you watch the cartidge being picked up check that the screw is exactly in the centre of the cartridge when it begins turning. If it isn’t you will get the grinding noise you described and you will see that the screw is not dead centre.
    This should fix itself if you shut the power off to the printer and switch it back on again – the head head should re-align itself properly when the machine is switched back on. If it doesn’t, check that the drive mechanism which runs the head left and right hasn’t developed some problem that is causing the misalignment.
    I had the very same problem two days ago which was cured simply by switching off and back on again 😀
    Try it again today – you may be pleasantly surprised to find the problem has resolved itself 😉
  • Kev
    11 June 2004 at 17:14
    Tried everything now apart from hitting it with a hammer. So have given in and took it down to Roland in Swansea 🙁 . It only came back 2 months ago for a new head. Hope it is a head alignment prob as they said the would do it free of charge (i am not betting on it though)
    Thank you all for the help (again)
  • Mike Rogers
    11 June 2004 at 17:24
    I did some freelance work for a company with a PC60 and the same thing happened to me whilst operating. It was an alignment problem which seems to have happened to them a couple of times. There is a set process for realigning which consisted of take the cover off and pressing sequence of buttons putting a tape in each in turn. Check the manual but I had a feeling they rang the supplier who gave them instructions over phone. It only takes 2-3 minutes to do. Give your supplier/roland a ring for the sequence. If any problems I will try and get the instructions
    Mike
  • Kev
    11 June 2004 at 18:39
    Cheers Mike
    I am collecting the machine back from Roland on Wednesday and will ask them about the routine
    kev
  • Bill Dewison
    11 June 2004 at 20:47
    Glad you’ve sorted it out Kev, as you say, hopefully head alignment, no charge and back to printing by the following morning 😀
    Cheers, Dewi
  • Mike Grant
    11 June 2004 at 21:27
    KEV YGM! 😀
  • Bill Dewison
    11 June 2004 at 22:01
    ok, I give in, what does YGM mean Mike? 😕
    Ya Gonna Melt?
    Young Guns Meet?
    Yellow Goes Magenta?
    😕 Puzzled!
    Cheers, Dewi
    11 June 2004 at 22:08
    maybe you got message?? 😀
    Nik
  • Bill Dewison
    11 June 2004 at 22:10
    😕 Ying Gai Moke? No idea what it means, but it sounds all japenesey 😀 😀
    Cheers, Dewi
  • Gordon Forbes
    12 June 2004 at 00:37
    You Got Mail maybe or You gone MAD!!!
    Goop
  • Kev
    12 June 2004 at 17:25
    Cheers Mike
    RYM (recieved your message 😀 😀 😀 )
    Sorry could not resist
    12 June 2004 at 22:30
    WTFITA 😉
    12 June 2004 at 23:28
    LLATEAWTF!!!!! 😀 😀 😀
    Nik (hint) footie!!!!!!!! 😛 😛
    Nik
  • Mike Grant
    13 June 2004 at 20:56
    You Got Mail! it is. Don’t you peeps speak the queens English 🙄
    Phill What the **** is that about 😮
    LMFAO 🙂
    13 June 2004 at 20:59
    there wont be much queens english spoken tonight!! maybe french though!! 😆 😆 😆
    sorry could not resist it!! 😀
    Nik
    13 June 2004 at 22:47
    Well done Mike – You got it in one 😆 😆
    HTFDYMT 😕
  • Mike Grant
    14 June 2004 at 22:44
    quote rightsigns:
    HTFDYMT 😕
    Quite easily actually 😆
    Better stop now before Rob deletes the thread 😳
  • Kev
    15 June 2004 at 17:52
    Just had a telephone call from Roland….
    Just to let me know the gears or something (thought of how much kicked in) have packed in. They then told me they will replace the complete head etc. free of charge 😀 😀 😀
    So picking it up tomorrow and can safley put my cheque book away…. TFFT
    Thanks everybody for the help
  • Bill Dewison
    15 June 2004 at 20:50
    Nice one 😀 Back to printing and a healthy bank balance to boot 😀
    Phill/Mike, any chance of a codebook? AIMS?
    Cheers, Dewi
