Home Forums Software Discussions Corel Software can anyone tell me why i keep getting a run time error 91?
  • can anyone tell me why i keep getting a run time error 91?
    Posted by Fiona McCabe on 16 November 2008 at 21:58
    hello, can anybody help me again!!!
    sometimes when launch cut plot i get a box with Run time error ’91’
    object variable or with block variable not set
    it has options of End or Debug, then everything crashes
    i have tried to find out about this in the help files, but i cant understand it
    can anyone explain in very simple terms!!!
    thanks so much
    Fiona McCabe replied 17 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
    16 November 2008 at 23:07
    whatever you are doing with Corel, you must be running something that is not part of normal corel install, so it has failed to continue running due to a program error in the ‘extra bit’.. You have to explain a bit more, like what machinery, corel version and what you was doing to create the error at the time.
  • Fiona McCabe
    16 November 2008 at 23:37
    thanks for your help,
    i am using corel x4
    i was making circle and rectangles so they look like christmas baubles and putting text into them, i need to cut them to go onto a hairdressers shop window,
    this error has come up loads of times, so i must be doing something wrong, i am just learning with corel draw 😮
    :lol1:
    forgot to add, the error comes up when i launch cut plot, i am using a graphtec CE5000-60 i have the correct plug in for corel draw X4
    16 November 2008 at 23:48
    Have a look here
    http://asknerd.net/index.php?option=com … view&id=47
    Dont know if it will help,
  • Fiona McCabe
    17 November 2008 at 10:27
    Thanks Peter, i will have a look there hopefullly will find the answer
    17 November 2008 at 10:42
    hi, i dont know anything about your cutter or software but X4 is slighlty different to X3 in for programming scripts… so does the CD / Software state that the Plugin will work with Corel X4 and it is that particular version?
  • Karl Williams
    17 November 2008 at 14:57
    I don’t know a great deal about Graphtec, but sometimes if you are opening winplot or other cut software in corel and the cutter isn’t on line
    it has a dikky-fit and shuts down.
    17 November 2008 at 16:03
    i think for x4 you need the latest CM2
    http://www.graphtecamerica.com/support.html
  • Fiona McCabe
    17 November 2008 at 22:00
    thanks for all your replies,
    i downloaded CM2 from Graphtec America and it works fine sometimes, its just now and again when i try to cut something this error appears then everything crashes, most annoying!!!! 😮
