Home Forums Software Discussions Signlab Software can anyone tell me why i cannot see imported eps files?
  • can anyone tell me why i cannot see imported eps files?
    Posted by David White on 20 January 2006 at 09:30
    Can anyone tell me why if I import certain eps files into SignLab they do not appear although there seems to be something there this also seems to happen with Corel 12
    Thanks in advance
    Alan Drury replied 19 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • John Wilson
    20 January 2006 at 09:34
    I get this with most AI files but the EPS ones I just open them in Photoshop and resave them as a earlier version….. sometimes it helps
    I know it’s not the best answer but it’s a work around until you find a proper one
  • Dave Bruce
    20 January 2006 at 10:03
    Some do that in Signlab haven’t managed to sort it yet, but if you open in Corel use Postscript Interpreted filter then export as eps and Signlab should open it OK.
    Dave.com.com.com
    20 January 2006 at 12:14
    May have something to do with fonts if in the eps or is saved as later version of eps withing Illustrator than the import filter supports. Dave is right about the Corel filter although this is not the case in X3.
    alan D
  • David White
    20 January 2006 at 16:44
    Thanks everyone ill give it a try
  • Clive Darbon
    24 January 2006 at 17:01
    Hi David, let me know how you get on, because I am having exactly the same trouble with SignLab and am thinking of buying CorelDraw. I won’t bother getting it if it doesn’t solve the problem!
    I believe Illustrator 8 and below all work fine with SignLab but the later versions don’t. I think it has something to do with fonts not being converted to paths though I’m not sure?
    Spooky
    24 January 2006 at 17:15
    We all get problems with EPS for other applications… The EPS format has been butchered around.
    EPS can be an Illustrator File
    EPS can be embedded Postscript file
    EPS can also be DCS seperated output
    EPS can be a badly named Postscript output file
    EPS can ….
    its goes on and on… luckly we have PDF now
  • Clive Darbon
    24 January 2006 at 17:19
    Thats true Dave, but can you manipulate a pdf file?
    PS I’m not a techie as you may have guessed, just a signmaker that likes things to work – no questions!
    Regards, Spooky 😉
    24 January 2006 at 18:18
    Signlab 7.1 imports pdf very well. Corel V12 will import pdf well but X3 is better. Fonts embedded in pdf will import as fonts/text or curves SL 7.1, fonts are fonts even if the font is not on your system. In X3 fonts/text are text and may be substituted if font not on your system or curves. Font shape is there but not editable text. It depends what version of SL or Corel you have or want X3 will import CS I think but not CS2. If you upload it here I can check.
    Alan D
  • Gordon Forbes
    24 January 2006 at 22:15
    Read the signlab web site they now have a forum. If the new version it is to do with importing things to different layers automatically on import. so check if you have multiple layers?
    Goop
    25 January 2006 at 08:26
    Yes very good point, later builds are showing imported files coming in on different pages rather than layers, grouping sorts this apparently. Goto http://www.cadlink.com and go through the Infosource links to forum. Any questions can be posted there and the Cadlink guys to respond virtually on a daily basis.
    Alan D
