Home › Forums › Printing Discussions › Uniform Printers › can anyone tell me the length limit please?
Posted by Peter Munday on 9 July 2008 at 16:26Just printed a ten meter banner today, and all was running well until it stopped 1 meter short of the finish 👿 👿 👿 👿 Can anyone tell me if there is a length limit, I’m using troop version 6 on a Grenadier 2
The job needs to be delivered at 9:00 am 😮 😮 😮Peter
Alan Drury replied 17 years, 5 months ago 6 Members · 13 Replies -
thats a sod
where it stopped printing did it have the faded printed passes or a perfect fully printed end, even though its in the wrong place.
years ago colour rip had a mind to do that and i found it was the size of the input file to big.
others
computer went to sleepchris
Chris it stopped printing with a nice sharp edge, and then just fed through blank media until the end of the job.
thats exactly what used to happen with colour rip.
what size is the eps length and height and mbs
It’s running from a pdf at 25% final size, it takes about 70 minutes to rip 😮 😮 😮
I hate it when printing a long banner and i’ve been keeping the banner slack from the roll, (so that the printer does not have to pull at the banner resulting in the printer heads rubbing over the banner and ruining the print). Then a customer walks in and i forget about the banner, the next thing i remember about the banner but it is too late!! I rush back to the machine but find the drag from the print head all over the print, i start ranting and raving and kicking the sh*t out of the nearest employee 😀 i mean cardboard box!!
I used to have to start again but now i print the end section and weld the two together, the welders are pricey but they reduce stress (until you burn yourself on one), then you want to murder the cardboard box, i mean employee!! -
all i can suggest is to try and reduce the pdf size.
when ripping big stuff i used to watch the progress meter and if it got to around 85% then finished very quickly i suspected this fault, so would reduce the input file till it looked like its riped correctly.
unfortunately it does not show as a fault in the finished rip size or prevew
I had that problem. Always stopping short 1ft from the end. I cured it by not holding any more jobs in the jobs queue than necessary. I delete each job on completion and don’t rip the next till its done. It’s a memory problem I think.
Hi Peter
Sorry I know its too late for this job but Mike is on the right track.
We had exactly this issue until we cleared all the print queues etc. I also think your file is too big if its taking that long to rip and that alone can cause probs.
Hope you get it sorted.
Cheers. Nick.
12:30 and it’s just finished printing 🙁 😀 I had to take it into Corel, enlarge to final size and export as a tiff. It took 24 minutes to rip and printed just fine. It would seem there was a fault in the pdf. 👿 👿 Still only nine meters of banner pvc wasted + the ink + my time.
Peter, how was the pdf produced? customer supplied/Publish to pdf in Corel or similar/printed to Acrobat or similar.
Alan D -
Alan not sure which program was used to create it but the customer supplied the pdf.
quote :Still only nine meters of banner pvc wasted + the ink + my time.
Get a banner welder from leister, just weld the end bit on the end. No waste 😀
Peter, did the file have a load of transparencies and drop shadows these are notorious in expanding file sizes and this would apply to anything producing pdf/Postscript by creating a tif you effectively flattened the image and therefor would have simplified the file. Just a guess.
Alan D
