Home Forums Software Discussions Corel Software Can anyone tell me how to set up Corel Draw 12 please?
  • Can anyone tell me how to set up Corel Draw 12 please?
    Posted by masairotts on 11 September 2004 at 21:11
    Can anyone tell me how to set up Corel Draw 12 to cut direct to a PNC 900
    Paul
    J. Hulme replied 21 years, 3 months ago 6 Members · 18 Replies
  • 18 Replies
    11 September 2004 at 21:28
    have you installed the driver for your cutter?
    Nik
    11 September 2004 at 21:34
  • masairotts
    12 September 2004 at 15:36
    Yes have the printer driver installed but am having problems working out the correct setting for coraldraw to get it to send the data to the printer.
    Paul
  • masairotts
    12 September 2004 at 15:56
    What I should really say is that I am having problems converting a design into a cuttable format.
    Paul
  • davebrittain
    12 September 2004 at 21:23
    you have to asign a colour called contorcut for the cut line pick a colour and rename it then use it as the outline colour for your cut path
    12 September 2004 at 22:04
    there you go paul!! best left to the experts!! 😛
    Nik
    ps. i actually got the same answer from steve & carrie!! a wee while ago!! 😳 😳
    :doh:
  • Andy Gorman
    12 September 2004 at 22:10
    Nik,
    Did you solve the cutting problem you were having from coreldraw? I’m still getting iffy cutting quality from corel, but it is fine from Illustrator.
    12 September 2004 at 22:15
    nope !!! big g 🙄
    still trying, cannot get a good cut in coral!! illustrator? don’t have cuttiing bit’s & bobs!!! :ball:
    Nik
  • Andy Gorman
    12 September 2004 at 22:21
    I was told by the Graphtec technical support that Corel does not give good results when cutting curves, when outputting as a printer. Fortunately, the driver disk had an add-on for illustrator, which works perfectly. Only thing is, I hate using Illustrator!
    12 September 2004 at 22:24
    ye me to………….. :hung:
    Nik
  • Andy Gorman
    12 September 2004 at 22:27
    Another thing I found, (still on topic, I hope), when cutting from coreldraw the maximum cut seems to be about 2.7 metres. Then it cuts a vertical line and stops. Using non ‘sign’ software is great if you’re on a budget, but there are limitations.
  • Carrie Brown
    Nik & Big G
    We still cant quite work out what problem you are having?? We design in corel we print using corel and we cut using corel, we do not get any jaggy edges or any iffy cutting problems at all with corel. The edges of circles etc are smooth.
    Edit: We have cut to a maiximum of just over 3mtrs with corel. We do have signlab and illustrator but as we have been using corel from the very beginning we still have yet to make the swap over …….. in other words we still havent had time to learn how to use the others properly yet :lol1: 😳 But for a cheaper package corel works great for us and as I said above no cut problems.
    Carrie 😀
  • J. Hulme
    12 September 2004 at 22:28
    quote davebrittain:
    I can’t understand the reason why people don’t save all this hassle and buy real dedicated signmaking software, complete with drivers, cut lines, profiles, fonts, etc etc instead of trying to do it on the cheap? Corel causes sooooooooooooooooooooooooooooooo many problems, if you actually bought the right software in the first place maybe all these problems would be very very small, dedicated basic signlab is dirt cheap, you’ll earn it back within months, why make it so hard? especially when corel is probably more expensive in the first place. 😕
  • Andy Gorman
    12 September 2004 at 22:33
    Outline, I agree totally. Only thing is, self employed people have limited budgets and it’s a case of one expense at a time. Of course, when you fork out for a plotter, they tell you you can cut direct from whatever application using a printer-type setup. I found this to be not completely true.
    Carrie, what version are you using? Perhaps this is where the difference lies. I’m using ver 9
  • Carrie Brown
    12 September 2004 at 22:35
    Big G we use 8 & 10 …… perhaps if Nik is using 9 aswell and you both have same problem perhaps it is corel then???
    12 September 2004 at 22:36
    yes i have done outline!! 😛 😛
    but the colour output in ooooooooooooooooooooo is not very good!!
    compared to coral or signlab!! 😀
    i have tried and tried outline!! you must have a method!! (-)
    Nik ps. i use coral 11
    12 September 2004 at 22:52
    outline!! i thought you were on about flexisign! 🙄 🙄
    my apologies!! 😀
    Nik
  • J. Hulme
    12 September 2004 at 23:01
    quote niknaxpc:
    my apologies!! 😀
    Nik
    Now you’ve confused me too Nik 😕
    I hate flexisign, I’m a corel user 😕
