Home Forums Sign Making Discussions Neon, LED, Lighting Can anyone suggest a good router bit for cutter?
  • Can anyone suggest a good router bit for cutter?
    Posted by Martin Manley on 2 May 2008 at 12:34
    Can anyone suggest a good router bit/cutter for putting the groove in Dibond to get that nice rounded edge – using a hand router, not a computer…
    Martin (-)
    Peter Normington replied 17 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • Peter Dee
    2 May 2008 at 12:57
    I just bought a standard V bit and ground off the tip a bit.
  • Andy Gorman
    2 May 2008 at 16:34
    Yeah, what Peter said. Grind the point to give a 3.5mm wide flat end. When you use it, the resultant groove will look massive and you’ll think "Blimey" but it’ll fold up lovely.
    2 May 2008 at 16:50
    If you are making a tray, I would consider giving Cherwell a call for a quote, They do an excellent job, and and you dont have to mess around!
    I have made a few in the past, but now just buy them in (cherwells corners though are very sharp)
    2 May 2008 at 22:47
    we make trays…. this is the bit we order in for cnc… might fit hand router
    http://www.itc-ltd.co.uk/signMaking/Di_Bond.pdf
  • David Rogers
    3 May 2008 at 16:09
    The best router bit I’ve found is a ‘3/8 half round’. Folds up beautifully (allows for a slight overbend to relax back to 90. If like me you put glue (Evostik – serious stuff) into the channel it also holds & bonds it to a solid angle. The channel looks HUGE, but always folds up crisp. Done several 10′ panels with 50mm returns – no problems.
  • Pryam Carter
    3 May 2008 at 19:18
    Jag sign supplies sell the bit you need.
    3 May 2008 at 19:26
    quote Pryam Carter:
    Yes but bl00dy expensive… buy one from B & Q, good quality "v" bit £15 and grind it down as mentioned above…..
