Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Can anyone recommend a suitable lightbox supplyer?
Posted by John Harding on 27 February 2007 at 22:23Hi all
Can anyone recommend a suitable product
Basically I need a double sided lightbox up to say 1m w x 500mm h for internal use in a foodhall, the unit would be suspended from the ceiling.
Something with a modern look would be ideal maybe oval in shape
thanks in advance
John Harding replied 18 years, 9 months ago 6 Members · 10 Replies -
John I think I saw Ashby’s doing something like that, or try Cherwell 01280 840297, or menudiplays.co.uk
it’s a start point maybe other people have better ones.Lyn
Thanks Lynn I tried Ashby’s a bit expensive on this occasion so I will look at the others you suggest.
Anyone else?
thanks – John
http://www.signwavesgroup.com/en.php?/p … -lightbox/
Any use
following on from my earlier Post I’m still searching for the right thing.
Dave what you linked to would be perfect if it could be hung from two chains rather than a bracket for projection mounting.
Anyone 😕
try Bil at circlit.com
he may be able to change a bracket for you
brilliant productIan
John, I would have thought they would be able to adapt those to a more suitable sort of fixing arrangement for you without to much trouble. How do you intend to attach it to the ceiling? Does the foodhall have solid ceilings or suspended ceilings? If it has suspended ceilings then it might be worth checking what is above them and how you would rig something up to take the weight of the box.
as has been said, circlit do some nice circular projectors.
printone now offer some good priced circular projectors.i am not sure if this would appeal to you, but it does work well and can be mucy cheaper than having one built from scratch.
contact a sign firm that makes BUILT-UP 3d LETTERS.
for them this is like making a letter "O" (if you know what i mean) not hard at all and it can be made to your spec. -
Thanks guys
circlit look possible too -will try monday
Rob have you got a contact for printone please
printone do a 75cm oval, d/sided "top fixing" for £60 john
01254 704330
