Home Forums Sign Making Discussions Graphic Design Help can anyone help with van layout please?
  • can anyone help with van layout please?
    Posted by TimDouglas on 10 August 2007 at 23:17
    Hi folks, Have done this design for an electrical contractor just starting out. If anyone has any time to give me some inspiration it would be greatly appreciated . To all who have helped me in the past im well on my way and 20mins after taking my Roland gx 24 out of the box i was making perfect cut graphics. Have done about 8 paying jobs so far, all small scale.
    He has no limitations on design . He does want it plain and not over the top, The van is metallic silver. I thought that blue and white mix would be best, he has said he likes bright green and black but I’m not sure.
    Also after I have it designed I know I have to enlarge to 2000% . How do I find out if what i designed will fit in my 24" cutter ? Don’t like splits and would rather reduce in size.
    Jason Xuereb replied 18 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Jason Xuereb
    11 August 2007 at 13:17
    Rejigged abit. Logo abit bigger and colours changed.
  • TimDouglas
    11 August 2007 at 14:39
    Thanks not bad, have a few options to show him now. How do i use the gif file or do i just copy the ideas in coreldraw?
    11 August 2007 at 16:25
    Tim, I think you are going to have to tweak it a little looking at your design, the oval as it stands looks a little bit big if you want to cut it in one piece on a 610 plotter. The panel depth on a vivaro is about 660mm if I remember correctly. With a 610 plotter you will probably only be able to plot up to somewhere around 590mm. I can sometimes get my graphtec to plot a bit wider but with the rollers at the very edge of the vinyl you risk the tracking running off.
  • TimDouglas
    14 August 2007 at 15:04
    jxuereb, Hi the client loves your first design eakin 2 . Not so fussed on my designs ! grr, any chance you could post it as a use able file for corel x3.? Save me having to draw again, Englarge all by 2000% ?
  • Jason Xuereb
    15 August 2007 at 00:37
    Let me know if these don’t work. I don’t use corel.
  • TimDouglas
    15 August 2007 at 12:02
    Worked great, many thanks . Will let you see the end results
    TD
  • TimDouglas
    8 September 2007 at 20:24
    Little advice here fitting this tomorrow morning, should I center all the graphic ( swoop + writing ) or center from the ( EAKIN ) ? Do you know what i mean? Center from eakin makes the righting read correct but then its off center when the swoop is on and dont want anyone thinking i cant use a tape measure..
    8 September 2007 at 20:26
    i would centre the whole logo, otherwise as your posted photo it looks a bit off to the left with too much space 😀
    8 September 2007 at 20:28
    I agree, centre the entire logo. 😀
  • Jason Xuereb
    9 September 2007 at 03:41
    I agree with the lovely ladies. Centre the lot.
