Home Forums Software Discussions Corel Software can anyone help with exporting corel files please?
  • can anyone help with exporting corel files please?
    Posted by ANDREW S on 25 August 2005 at 08:14
    Good Morning All,
    I have a customer who supplies corel vectorised files to me to cut.( Lucky you I hear ! ) however he supplies them on floopies which are not always reliable, I thought I would able to accept emailed files but for some reason my machine turns them into Acrobat files, which are no good to man nor beast.
    Appologies in advance probably me being thick
    Andrew 😛
    David Rowland replied 20 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
    25 August 2005 at 08:45
    are you using Outlook/Outlook Express / Web browser to read your mail?
    attachments normally appear correct.
  • ANDREW S
    25 August 2005 at 08:58
    Yes Dave, Outlook Express at both ends ??
    25 August 2005 at 09:24
    hmmm… when you receive the files in Outlook Express, under the attachments section of the email they are called “File1.cdr” and alike… when you “Save the attahcments to a folder”… they automatically change into File1.PDF?
  • Steve Dawson
    25 August 2005 at 09:55
    i may be barking up the wrong tree here…..
    but tell me this , are you saying when you try and open them , acrobat comes up and then gives an error ?
    if so , one of 2 things could be going on here….
    1. sounds daft , but do you have corel loaded , if not , it will try and open in the next best program
    2. if you do have corel loaded , are your associations set right , i.e. , in explorer , find your saved file , right click , properties , and check that “opens with” is the correct program…an easier way around this is to open corel first , then use “file” “open” to load in your file….
    sd
  • ANDREW S
    25 August 2005 at 09:59
    Thanks Guys,
    The file is recieved as an acrobat file , ie seems to have changed itself in transit.
    But I will try Gypsys second point later
  • sjet2002
    25 August 2005 at 10:00
    Have you tried sending the .cdr extension files, attached to the email in a zipped format.
    This will obviously mean that your supplier will need the relevant software to compress the file before attaching.
    You should then be able to save the zip file first before un-compressing it to reveal the enclosed .cdr file.
    I normally use WinRAR, when I encounter difficulties like this.
    Are you using Windows XP, which service pack ?
    Ian.
    25 August 2005 at 10:04
    More likely the customer did Publish to PDF out of Corel or Illustrator uses PDF as native.
    When ever I send artwork to someone I sent as PDF, gets around font issues etc.
    no worries… cheers
