can anyone help with cadet ink dumping problem?
Firstly; I’d like to thank the regular posters of the forums for their excellent advice and an invaluable resource. Although this is my first posting, i have gained alot from be being a silent reader!
I’m soon to be opening a sign shop and have purchased the following S/H equipment for this mission; A Uniform Cadet SP-750C (running a bulk ink system with ActivaSOL), an Ezy-Taper (1300mm) and various cutting systems etc. I already have an Epson 10600UC (44") which has mainly been used for interior exhibition jobs and Giclée prints and an old Roland PC-60.
Unfortunately; I’m having a problem with the cadet. I haven’t really used it much yet; however, I have printed something everyday and cleaned etc. as instructed. It has started dumping loads of ink into the waste bottle, particularly cyan for some reason!? It’s now dumped x3 full waste bottles! Which has cost me dearly! When the ink is filled it does print well and everything else appears fine?! The firmware was upgraded to v.6.60 but the ink disposal problem started at least a month after that. It seems to dump ink even when off at the mains supply! The cadet has recently been serviced and has had both print heads and many other parts replaced with new. It identifies itself as a Roland SP-300V on the front LCD panel and within Versaworks. Any suggestions would truly be appreciated as I will be reliant upon this machine in the near future.
Thank you in advance for your posts and I look forward to becoming an active member as my skills and experience grow. 😀
