Home Forums Software Discussions Corel Software can anyone help with an outline problem?
  • can anyone help with an outline problem?
    Posted by Paul Goddard on 15 October 2009 at 10:57
    Hi trying to create outline/ shadow effects doing ok but been asked to do an outline thats not as full as the main text so if you got a B it will only be a line and couple of curves. Any help please.
    Paul
    mod-edit please use descriptive titles for topic headings
    Graeme Harrold replied 16 years, 2 months ago 6 Members · 11 Replies
  • 11 Replies
    15 October 2009 at 11:29
    That’s going to depend on what software you are using as they don’t all work the same way.
  • Paul Goddard
    15 October 2009 at 11:51
    hi its the lateset x4
  • John Harding
    15 October 2009 at 11:56
    dont know the answer – but brows the corel forum will probably give you the solution
  • Mike Fear
    15 October 2009 at 16:34
    Do you mean to give the effect of just the offset shadow, without the original text on there ?
    If so, the way I do it is to make the text, convert to curves, then copy and paste the text so you have two copies of the same thing, one on top of the other.
    Next move the top one so it is offset from the bottom one ( one space up and one space left, or whatever you need to get the look you want ) then select both and minus the back from the front, leaving just the shadow as an object on its own.
    Not sure if this is what you are trying to do as your description isnt very clear ?
  • Tim Hobbs
    15 October 2009 at 16:54
    Hi Mike
    What software are you using?
  • Tim Hobbs
    15 October 2009 at 16:57
    Sorry Mike
    Just read it properly….. X4 😳
    I’d go with Mike’s suggestion but you could also use the Smart Fill Tool for the same effect.
    Tim
  • Mike Fear
    15 October 2009 at 17:00
    I use X3, which is basically the same.
    Smart fill is OK, but tends to be too ‘automatic’ for my liking, doing it manually means you have a lot more control over fine tuning positioning etc…
  • Paul Goddard
    15 October 2009 at 21:52
    thanks guys i will try and see if thats the effect i actually want or i will upload a photo of what im trying to do .
    paul
  • Graeme Harrold
    15 October 2009 at 22:03
    Think you need 2 B’s, move the second (lower) to the position you need it. Convert to curves then Weld using the "back minus front tool………….simples (if that is what you were after)
    Example Here – http://www.uksignboards.com/viewtopic.php?p=345641#345641
  • Paul Goddard
    17 October 2009 at 09:49
    Thanks guys thats a start if i dont want a much out line do i just make the sizing smaller at first?
    Paul
  • Graeme Harrold
    17 October 2009 at 11:02
    Dont make your outline too small, you will find you get problems with longevity if you are using cut vinyl……………..
