Home Forums Vinyl Cutter Discussions Roland Cutters can anyone help with a roland PC-60 sensor issues please?
  • can anyone help with a roland PC-60 sensor issues please?
    Posted by Laura Michelle on 31 January 2008 at 19:58
    Hi all I am new to UKSIGNBOARDS.COM, been reading loads of topics discussed on here and they have been very helpful! So thanks everyone for all the great answers given.
    I currently have a Graphtec ce5000-60 , ce5000-120 and a Roland PC-60.
    The Roland was bought of eBay a while ago and I have never got around to using it so yesterday i thought i would have a go.
    I have read the manual and looked for help regarding this matter on the internet but have not yet come to a solution.
    I have loaded the vinyl into the Roland correctly, aligning it to the grit rollers etc and making sure it covers both the front and rear sensor. Now when i put the front down, both the piece and roll LED’s flash as if its not been loaded correctly but it has been loaded correctly 100%.
    I am totally out of ideas on this, I am thinking maybe the sensors are faulty and dont work?
    If anyone could help me or give me any advice you would be life savers! Thanks for your time
    Laura
    Michael Potter replied 17 years, 9 months ago 3 Members · 3 Replies
  • wink type
    18 February 2008 at 10:33
    Hi Laura,
    I have been using a PC 60 for quite a while now, and the only thing I can offer is that the colour cartridges may not be correct. My machine does this if I wish to print CMYK, when I may have a solid red/blue cartridge installed (or no cartridge). Hope this helps.
    18 February 2008 at 10:59
    quote :
    just duplicated this on mine if a pinch roller is out of alignment then the leds flash also the knife is parked at the roller where the fault is.
  • Michael Potter
    22 February 2008 at 07:00
    Hi Laura
    Sorry this is late but I am still wondering around my pc-60 in somewhat of a daze!
    I think the problem you described has happened to me and I think it is when I have set the machine up with a certain size of material and then I use a material that is actually larger than I told it to expect, then when I set the rollers out to the full width that i have put in the machine the rollers are wider apart than the machine expects. if I simply bring the rollers closer problem fixed.
    Hope that makes sense to you.
    Cheers Mike
