Home Forums Printing Discussions General Printing Topics can anyone help with a laminator problem?
  • can anyone help with a laminator problem?
    Posted by Andrew Fleming on 27 January 2010 at 10:36
    I am currently using a Kala cold laminator and it is a total disaster as i cannot get it now to run anything longer than about 4ft until it starts folding and creasing up.
    So time to get rid and put in a single top heat, can anyone tell me what is good around at the moment out at sensible money, i have looked online at the easymount (any stories on this)
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    M Brown replied 15 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • M Brown
    27 January 2010 at 13:25
    Hi Andrew,
    I have one of these but called a Guardsman from B+P. Mine works fine. It sounds like you don’t have enough tension on the supply roller that holds your media. I have that same problem till I ready my manual in the troubleshooting page. Tighten the thumbs screws a little and now I can laminate for meters and meters.
    Hope this helps a little
    From Mark
  • Andrew Fleming
    27 January 2010 at 13:35
    Cheers Mark
    On your supply roll does your vinyl come off the roll on the bottom or the top then down to the roller?
    There is 2 different ways to load
  • M Brown
    27 January 2010 at 15:09
    The media comes off the bottom of the supply roll, and then it goes over the the roller and double backs on its self. The liner is taken off the rolled around the top take up roller. The drive belt should be in a figure eight shape so the take up roll rotates in the correct direction.
    From Mark
  • Andrew Fleming
    27 January 2010 at 15:13
    Thats the way mine is, i will have to play some more with the tensions, i didnt think the tension on the take up was important?.
  • M Brown
    27 January 2010 at 17:59
    The tension is on the supply roll, not the take up roll. That’s what the thumb screws are for.
    from Mark
  • Andrew Blackett
    27 January 2010 at 18:11
    Dont have one of these machines but on our seal machine if the pressure is to high pushing down on the top roller it’ll crease up. Trying backing off the psi a little.
    Andy
  • M Brown
    27 January 2010 at 18:19
    When it comes to pressure on the rollers I just turn them down till the rollers touch and then give half a turn more for the pressure, works just right.
    From Mark
