Home Forums Vinyl Cutter Discussions Roland Cutters can anyone help please with cutting problems and PC600?
  • can anyone help please with cutting problems and PC600?
    Posted by Edfalstrem on 12 August 2007 at 23:36
    I have a PC600 which I use mostly for cutting heat seal material. Recently I have been experiencing problems with cutting and subsequent weeding. The cutter is skipping small cuts and other cuts look like perforation marks – a series of single holes as opposed to solid cut. It is very frustrating to weed on detailed images. Anyone have any suggestions?
    Edfalstrem replied 18 years, 4 months ago 2 Members · 2 Replies
    13 August 2007 at 00:00
    sounds like the blade holder requires attention.
    remove holder then blade and wash out the bearings with wd40 spray, dry as best and try
  • Edfalstrem
    13 August 2007 at 19:56
    I followed your instructions and it has solved the problem. There was a lot of debris around the blade when I removed the top. I cleaned it off, gave it a shot of WD40 and it is now working great. Thanks a lot. You have made my weeding task so much easier.
