Home Forums Software Discussions Signlab Software can anyone help please signlab is not cutting?
  • can anyone help please signlab is not cutting?
    Posted by Dale Hughes on 22 March 2006 at 09:29
    Hi Guys i have got a Pcut 630 (usb) version from Alan Flynn signs all works great with winPCsign but i am trying to use sign-lab 7 i have set it up on com 1 downloaded the latest drivers also had the drivers sent from Alan but every time it communicates it sits there saying waiting for DSR have any of you guys had this before i have tried messing around with the settings but still nothing all the help would be greatly appreciated
    Jarrod replied 19 years, 2 months ago 3 Members · 5 Replies
  • David Rogers
    22 March 2006 at 09:51
    Simple answer is ‘com1’ is not a USB port – it’s a serial cable.
    Does your plotter only have a USB link?
    Scroll UP the list of ports & you might see ‘USB0001’ – try that.
    And use the plot spooler is required.
  • Dale Hughes
    22 March 2006 at 09:55
    Hi David i have tried USB001 nothing happened the USB port on the machine installs as a USB to serial converter that why i put it on com1
  • David Rogers
    22 March 2006 at 10:18
    Can you get ‘plotter ID’ or ‘page size’
    If you can’t, then Signlab can’t see the plotter at all (regardless of what windows says).
    In all honesty – I tried installing the USB with my SL 7 & Summa – gave up as could only pick up as a printer option. (Previously tried it with a Graphtec & e6 – no joy)
    So, am I right in thinking it’s a standard PC USB to Plotter USB port and not some sort of weird hardware adapter?
  • Dale Hughes
    22 March 2006 at 10:28
    Hi David it is a USB version but as its a Pcut that does not mean standard it works fine with winPCsign on com 1 just not with sign lab thanks for your help mate i will keep trying
  • Jarrod
    15 September 2006 at 07:22
    Dale_2005,
    Did you find a way to get SignLab to talk to your USB PCUT?
    I am in exactly the same boat. I hope you found a way around it and you can share the solution. Or anyone else out there that may have any ideas.
    Regards,
    Jarrod
