Home Forums Vinyl Cutter Discussions Summa Cutters can anyone help my plotter is not cutting properly?
  • can anyone help my plotter is not cutting properly?
    Posted by Kev Dunn on 22 January 2008 at 13:33
    Hi All,
    I’m having some bother with my Summa D60. I have attached a photo below…
    The machine is leaving some parts of each letter un-cut. So its a real pain to weed.
    I’m doing alot of these stickers and it’s not cutting the same bit on each letter every time.
    Summa D60 with Corel Draw and cutting Oracal 651 and 751.
    It doesn’t change whether it’s a new blade or not…
    Anyone any Ideas?????
    Thanks alot guys,
    Regards,
    Kev.
    Peter Dee replied 17 years, 10 months ago 10 Members · 12 Replies
  • 12 Replies
  • Chris Windebank
    22 January 2008 at 13:48
    is your cutting strip worn? can you feel a groove with your fingernail?
  • Kev Dunn
    22 January 2008 at 14:04
    Hi mate,
    Yes there is a slight groove…
    Could this maybe be the problem. How do you change this?
    Regards,
  • Chris Windebank
    22 January 2008 at 14:06
    do a search for signwizard on the net, I am sure they sell these machines and will have spare cutting strips, better sill ask them about your problem
  • John Childs
    22 January 2008 at 14:07
    Blade offset.
    22 January 2008 at 14:21
    Looks like blade offset to me too.
  • Brian Hays
    22 January 2008 at 14:55
    Also check the blade holder to make sure the bearing is moving freely.
  • Kev Dunn
    22 January 2008 at 15:16
    Hi Guys,
    Thanks for the suggestions.
    I have adjusted the blade offset (as per manual) to get the squares perfect.
    I can spin the blade 360 degrees with my finger tip.
    I swapped the cutting strip from side to side.
    But it is still the same.
    Any more Ideas?
    Regards,
    Kev.
    22 January 2008 at 16:24
    It may be possible that the machine is taking the offset instruction from the cutting software, there is usually an option to take the pressure and other settings from the software rather than the plotter settings.
    I dont know the summa, or your cutting software? so I may be wrong but worth checking.
    22 January 2008 at 18:02
    Check there’s no free play between the motor spindle that drives the rollers and the sprocket that is attached to the drive belt. My Summa d610 once had a similar problem and it turned out the grub screw that holds the sprocket onto the spindle from the motor had come loose allowing a small amount of free play between the rollers and the drive motor.
    22 January 2008 at 18:19
    the point where the faults are is the start and finish points of each loop. all other courners cut ok.
    so phill may have a good point, or the vinyl backing is buckling, or the pen down is lazy.
  • Jan Storgaard
    6 March 2008 at 17:19
    I think there is an "overcut" setting in the summa cutters display panel. Check if the endcut is indeed overcutting the startcut
    Just an idea
  • Peter Dee
    6 March 2008 at 19:03
    I heard of this quite a few years ago. It was down to the initial setup of the machine having been altered.
    Have a look in the manual for setting it up from scratch.
