Home Forums Software Discussions Corel Software can anyone help me with contour problem please?
  • can anyone help me with contour problem please?
    Posted by Harry Cleary on 7 March 2008 at 20:32
    Using X3….I have created a contour on a logo I want to use at various sizes, is there a way to ‘lock’ the contour so that it stays in proportion to the letter size, without having to do it manually each time I resize. Hope that makes sense.
    deco replied 17 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Warren Beard
    7 March 2008 at 20:40
    If you scale both up together as 1 unit then it should not be a problem. Can you post a picture of what you are trying to do as it is a bit confusing?
    Warren
  • Harry Cleary
    7 March 2008 at 20:56
    posted a pic here Warren.
    http://www.uksignboards.com/viewtopic.p … 188#265188
  • Glenn Sharp
    7 March 2008 at 21:25
    Harry…I’ve had a couple of beers so excuse me if I’m wrong
    If you break the contour apart it should then scale up and down proportionately with the text……………..I think
  • Warren Beard
    7 March 2008 at 21:42
    If you want the proportions to always be the same then simply scale up as 1 unit. Do not increase the point size of the text, the text must be a path and then group all together and then scale it all up at once.
    Hope I understand and it helps.
    Warren
  • Harry Cleary
    7 March 2008 at 21:47
    Cheers Glenn…but that was what I was hoping to avoid doing as I have quite a few vehicles to do of differing types.
    Warren, that’s exactly what I did there…..grouped and enlarged the whole lot.
    I think that is what you mean, but Corel seems to make an adjustment itself.
  • Glenn Sharp
    7 March 2008 at 21:53
    Harry….not sure if I’m following you but the breaking apart is just an instruction….you don’t have to physically separate the text from the outline
    if you break apart and then group them it still scales proportionately
  • Warren Beard
    7 March 2008 at 23:08
    can you show a before and an after picture (quick before Rob delete’s the other post 😉 )
  • Harry Cleary
    7 March 2008 at 23:14
    Cheers lads……….sorted here. 😀
  • deco
    7 March 2008 at 23:33
    Hi there,, to increase or decrease in proportion a contour, you must activate the "scale image" once you open the CONTOUR icon.
    Hope it helps
