can anyone help me with blade problems and the CX 24?
i have a slight problem with my roland cx24 and any help or advice would be appreciated.
I recently bought some (supposed) roland blades (60 & 45deg ) via a well known auction site as the blade in my machine had been there since i bought it two years ago. [Questionable authenticity !!!!!!!!!]
A customer has asked me for 2 small text decals 100mm x 9mm high(small i know but not impossible??)
When i cut these out (@ 5cm speed) the faceting on the curves was appalling. I did a standard test cut and the edges of the square where rounded on three of the corners and did’nt meet at the end.
I tried both the 45 & 60 blades on various settings with equally appalling results……. I also cut a text decal @ 550 x35mm with similar results though not as noticeable.
I read the help cd and it says to adjust the cutter force & blade extension, which i have tried to no avail. I have resorted to the old blade which looks better but still not good. It also mentions rollers needing replacing etc.[i] Do i need to adjust the offset to compensate for the blade difference??
[ii] I appreciate i may have to get the machine serviced , rollers etc (anyone got a contact for someone in the leeds / huddersfield area for this??)
[iii] The blades may be cr@p and a testament to the ‘get what you pay for’ – that and being made in mexico (:)
[iv] Is this to be expected at such a ‘small’ size??? I have done some of similar size and can’t remember them being as badly faceted
I am tearing my hair out over this
Ben @firewithfire
