Home Forums Vinyl Cutter Discussions Summa Cutters can anyone help me source summa plotter blades please?
  • can anyone help me source summa plotter blades please?
    Posted by Warren Beard on 15 March 2007 at 21:27
    Hi Guys
    I am looking to keep a spare blade and was wondering where is the best place to get them from.
    Also I have read threads about angles of blades, is there a specific blade I need to ask for or should I keep using the same angle as per my current blade and how do I find out what it is.
    I have a Summa D60SE
    Any help or leads will be great
    Thanks in advance
    Warren
    Kevin Flowers replied 18 years, 10 months ago 4 Members · 5 Replies
  • Kevin Flowers
    15 March 2007 at 22:10
    Warren
    Edward Mathius does replacement blades for the Summa plus he also does is own called Smart Knives. They require no setting other than force set in the machines menu by the key pad. Just tell them the machine you have & you’ll get the right ones.
  • George Kern
    15 March 2007 at 22:25
    quote Warren Beard:
    Hi Guys
    Thanks in advance
    Warren
    Warren,
    Different plotters/cutters use different angled blades for different materials. For our Mimaki ones we use:
    37 degree for 2-4 Mil. vinyl (cutting normal lettering / graphics)
    50 degree for 2-4 Mil. vinyl (cutting small lettering)
    56 degree for 4-12+ Mil. w/ .75 mm offset (cutting paint masks, stencils, reflectives)
    If im not mistaken Summa’s have 36 degree and 60 degree blades available at most suppliers / aftermarket blade manufacturers.
  • David Rogers
    15 March 2007 at 23:56
    I buy mine from Victory. About £15 each – and they usually have a 2 for 1 offer on. So stock up & buy a few!
    Blade holders on the other hand – about £60 a pop. Lasted 3 years though before the bearing fell apart!
  • Warren Beard
    16 March 2007 at 08:53
    Thanks guys
    I only knew of Edward Mathius as I have spoken to him before. I will look into all options.
    Thanks again
    Warren
  • Kevin Flowers
    16 March 2007 at 12:53
    Warren
    one point to remember is Edward Mathius supplies a load of resellers of blades which means you could end up with the same item but different packaging. I think he also supplies some cuttermanufacturers as well.
