Home Forums Sign Making Discussions General Sign Topics can anyone help me set up these pantone colours in rgb?
  • can anyone help me set up these pantone colours in rgb?
    Posted by Liam Pattison on 21 February 2010 at 16:53
    Hi there
    i am trying to set up sepecific pantone colours in some artwork in illustrator. I can see how to enter the values for cmyk and rgb but i’m not 100% sure how to get these values for pantone colours.
    I’ve downloaded the colour bridge software from the pantone website and the library but i’m still a bit stuck.
    the two colours i need to use are-
    Mil Blue Pantone PMS321 (Pantone Coated 321 CVC)
    Mil Red Pantone PMS200 (Pantone Coated 200 CVC)
    the rgb values i’ve got for the blue are R:0 G:52 B:54
    and the values for the red are R: 73 G: 7 B:17
    Can anybody tel me if this is correct and can you also tel me the CMYK values for both colours so i can enter them aswell.
    Thanks if you can help!
    Liam
    Liam Pattison replied 15 years, 10 months ago 2 Members · 4 Replies
    21 February 2010 at 18:20
    I am confused why you would need to… most rips understand pantone colours. ( and these are measured in LaB )
    RGB is designed for adaptive colours (from a black background), so good for monitors and cameras.
    You can use a bridge (or software bridge) to convert pantone to CMYK to make it less likely a mistake would happen at press, but really its best to leave them as Pantone. You may have noticed that the software bridge way have given a warning when converting the colour, which is true, means it cannot convert it. So, Pantone cannot be 100% converted to CMYK but RGB gives a better range.
    I get off my tutor box
    For instance Photoshop CS4 claims:
    PMS321 could be C100, M17, Y39, K1 or R0 G137 B152
    PMS200 could be C18, M99, Y77, K7 or R190 G15 B52
    Use at your own risk!
  • Liam Pattison
    21 February 2010 at 22:14
    Thanks Dave
    I don’t know too much about rips as i don’t have a printer.
    I was just trying to set up the pantone colours correctly within the illustrator file incase i needed to send it to a trade printer so he has the colours correctly set up when he recieves it.
    Does this make sense?? Am i going about this the right way?
    Liam
    21 February 2010 at 23:29
    then leave them as Pantone colours, converting them is a mistake.
  • Liam Pattison
    22 February 2010 at 18:20
    Thanks Dave,
    i have now found the pantone swatches in illustrator, i thought you had to enter them in manually using their rgb or cmyk equivalents for some reason. I read a little bit and got the wrong end of the stick 😳
    thanks
    Liam
