Home Forums Vinyl Cutter Discussions Summa Cutters can anyone help me set up cutting sizes on Summa D60?
  • can anyone help me set up cutting sizes on Summa D60?
    Posted by Dave Armstrong on 2 November 2007 at 20:19
    Hi All
    In need of advice.
    I use, and have for many years a Summa D60 – Corel 11 and Sign Tools 3
    Replaced computer all working fine except when the job finishes cutting it used to roll of a bit extra vinyl and stop so that you could run a rabbit knife in the slot and cut of the job. But now it don’t do that. It stops and parks the drag knife and you need to roll the vinyl forward manually.
    Any help on how to set this up? After many years of ownership all instruction books are lost.
    Thanks Dave
    mod-edit please make one post per topic
    Dave Armstrong replied 18 years, 2 months ago 11 Members · 12 Replies
  • 12 Replies
  • Richard Urquhart
    2 November 2007 at 21:57
    Dave I have the same plotter but have never had the feature you had I have always had to push the down arrow to get the media to get to the point to cut off
    Rich
    If you do find out let me know
    thanks 😀 😀
  • Warren Beard
    2 November 2007 at 22:03
    me too 😉
  • Kevin Flowers
    2 November 2007 at 22:27
    i have a D60 & D120 & neither of them do it.
  • David Rogers
    2 November 2007 at 22:43
    D120 – arrow key for me too!
    Jogging forward automatically that 50mm or so would be a handy function…
  • Peter Shaw
    3 November 2007 at 09:17
    The replies indicate that it is not the cutter that does this but more probably your cutting software. As this has been reloaded it is the first place to look.
    D60 Manual: http://www.summausa.com/downloads/SummaCutManual.pdf
  • Michael Potter
    3 November 2007 at 23:43
    Me to Arrow keys
  • Nick Minall
    4 November 2007 at 13:18
    I think that is just software related, I can not do that with my Summa.
    Nick.
  • Matt Hards
    5 November 2007 at 08:57
    I use a D60 and i use manual arrows too, would be good to know if you find out how to do it though 🙂
  • Frank Droog
    6 November 2007 at 18:28
    look in your plotter setup of your software.
    In many programs, you specify additional move at end of job.
    It would default to zero on a fresh install.
  • Dave Armstrong
    6 November 2007 at 18:51
    Sat down today and looked at it.
    It is the cutter program, set the figure in the post cut feed off box and all works.
    Its a case of not remembering what you done all those years ago.
    Thanks to all for your replies
    6 November 2007 at 21:48
    lol, i think i’ll check that on mine, you do you mean this feature is in the summacut software ?
  • Dave Armstrong
    7 November 2007 at 09:03
    quote Hugh Potter:
    I have the feature in Sign Tools 3, which is what I use to run the cutter.
