Home Forums Software Discussions Corel Software can anyone help me please on how to do corel infills?
  • can anyone help me please on how to do corel infills?
    Posted by Adrian Neill on 10 October 2008 at 11:11
    Afternoon everyone ……
    I’m producing a visual for a client. Part of the new sign uses a stainless
    steel tube. On the right hand side you can see that i’ve infilled the part
    to look like stainless steel, but on the left it shows the tube with a bend.
    Basically …. is there anyway I can use a graduated infill to show that the
    stainless steel is a cylinder but so that it bends round with the shape ??
    I hope that makes sense ……..
    David Rowland replied 17 years, 2 months ago 1 Member · 1 Reply
  • 1 Reply
    10 October 2008 at 12:21
    perhaps, no easy way.
    I dont have corel to hand on laptop but here goes.
    1: Hopefully that is a shape, not an outline for a start, if not then Convert Outlines to Shapes menu item
    2: Use Node tool and break it apart so you are left with two curves. The left curve and the right curve. Colour one curve lighter then the other.
    3: Using the blend tool with 20-30 steps, blend the left curve to the right curve and it should blend over the bend.
    4: You should see a coloured pipe.
