Home Forums Software Discussions Corel Software Can anyone help me make something like this?
  • Can anyone help me make something like this?
    Posted by Reza Faezi on 26 February 2014 at 14:47
    Im new to Corel and cant get my head round how to do this exactly
    Any help whatsoever would be much appreciated 😀
    Hugh Potter replied 11 years, 10 months ago 7 Members · 11 Replies
  • 11 Replies
  • Harry Cleary
    26 February 2014 at 15:00
    Not sure exactly what it is you want to do. More info?
  • Reza Faezi
    26 February 2014 at 16:17
    It would help wouldn’t it 😕 (sorry)
    Im trying to morph the picture onto the console & control pads with the cut holes at an angle.
    Probably really simple to do but as i dont do much designing, its working out quite a struggle
  • Jon Marshall
    26 February 2014 at 16:22
    Would be easier to do in photoshop probably
  • Kevin Parr
    26 February 2014 at 19:27
    Im not exactly sure what you need to do in corel draw but i may be wrong are you trying to merge photos together so you can print onto vinyl so you can put on a controller if you are then look at this video http://www.coreldrawtips.com/site/merging-photographs
    if not so sorry
    26 February 2014 at 22:28
    Create a template of the finished cut shape
    fill with a image.
    Print and cut
    apply
    those or similar images may be under copyright if you intend to resell
    don’t understand what you mean by cutting at a angle
    26 February 2014 at 22:29
    fill with a image.
    Print and cut
    apply
    27 February 2014 at 10:38
    if you mean you want to make a photo like the above, layering a proto onto the object for visualisation purposes then you need to …
    draw a vector outline of the item you wish cover, all of the areas you want to see should be drawn around. Select all > Combine. lay the outline over the photo you want to ‘wrap’ around the object in the place you want it to be. select image>effects>powerclip>place inside container and select the outlines, the photo will sit inside the outlines, simply lay it over the object.
    this on took two mins and is very rough but shows the principle.. ..
  • Harry Cleary
    27 February 2014 at 10:58
    I’m sure you can get vectors of the controllers online, and just do as others say, use the ‘place inside container’ function.
    27 February 2014 at 12:12
    I think it’s time you invested in a new Telly Hugh you tight wad 😕
  • Reza Faezi
    27 February 2014 at 13:45
    Thank you everyone for you help/advice, i will give it a try
    27 February 2014 at 14:35
    quote Phill Fenton:
    it’s got all kinds of shades of grey… love my little moving
    picture box!
