Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters can anyone help me get KINGCUT A630 cutting please?
  • can anyone help me get KINGCUT A630 cutting please?
    Posted by Harry Cleary on 4 March 2006 at 18:59
    I havent used this machine in a while and I forget how to solve this problem. Everything is set up, the computer recognises the plotter etc, but it wont cut, any ideas? I know it is a simple fix, but I cant figure it out
    Lee Ballard replied 19 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mark Reed
    5 March 2006 at 20:14
    hello there, I had a similar problem with my ct 630, similar machine I think, had the problem when I had to change computer and the new one didn’t have a com port , so had to use a usb adaptor lead,and set up a usb port as a com port 1. what I found was the information was trying to load to the cutter to fast, so I had to go into the port properties or something, and slow the transfer rate down, this cured my problem. as you can tell I am a complete computer whizz ha ha also before you try that I assume you have got your cutter ‘ on line ‘ ie not displaying the x y coordinates.
  • Lee Ballard
    5 March 2006 at 21:40
    Hi there Harry,
    We run one and the only time we had the proble you describe we turned plotter off, closed sign cut, restarted sign cut and restarted plotter and all was fine.
    Lee
  • Harry Cleary
    6 March 2006 at 12:29
    Thanks Mark and Lee,
    Lee that solution didnt work out,
    Mark, I am a computer and technology fathead…lol
    What do you mean about showing the x, y, cordinates, my cutter shows ‘x-00
    y-00
    is that the problem?
    6 March 2006 at 17:30
    Harry, I don’t know anything about this particular type of machine, but is the plotter set up on the correct port? It could be that your software is looking for the cutter in the wrong place.
  • Harry Cleary
    6 March 2006 at 17:36
    Marcella,
    I have tried it on all ports, and nothing happens, however if I put it to summaUSB (the plotter is a KingCut) it moves the feeding wheels slighty but nothing else happens.
    It was working perfectly before.
  • Mark Reed
    6 March 2006 at 19:39
    hello again harry, on my P cut if the co-ordinates are showing on the display the cutter is NOT on line therefore dos’nt receive info from the computer, on mine there is an ….on line .. button on the control panel press this and on line should appear on the display and hopefully the cutter should work
  • Harry Cleary
    7 March 2006 at 11:23
    Hi all, just an update to say that I apprediate your help, Im waiting for Kjell at Kingcut to get back to me re; the problem.
    Mark, that button isnt on the Kingcut, but I think you might be close to the root of the problem.
    Thanks again
  • Lee Ballard
    8 March 2006 at 05:54
    Harry, just a thought, our kingcut runs through signcut but it is a version specifically for kingcut plotters. Could be worth checking out which version you have installed, we got both versions with the plotter.
    Lee
