Home Forums Software Discussions Signlab Software can anyone help i have signlab 5 and am having problems?
  • can anyone help i have signlab 5 and am having problems?
    Posted by geo142 on 7 March 2005 at 16:23
    hi every body can anyone help i have signlab 5 and am having problems
    cutting in windows xp but o/k in 98 please help as i am pulling my head off in dispair thanks goe 142
    geo142 replied 20 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Dave Ward
    7 March 2005 at 17:08
    I run signlab 5 on winxp home sp2 but have used it on win 98se too with no probs what actually happens when trying to cut ?
  • Paul Goodwin
    7 March 2005 at 17:27
    What service pack with windows xp you got?? i believe but not sure that sp2 has problems with it, may need a patch?
  • geo142
    7 March 2005 at 17:50
    hi i am on winxp home signlab cuts sofare and will then cut across the sign
    come back again miss some of that font and start cutting again somtimes missing more fonts any ideas
  • Paul Cox
    8 March 2005 at 00:40
    If i remember i dont think it was a Windows problem but a Signlab problem.
    Try ringing Cadlink cos i’m sure there is a Patch available from ALADDIN who make the dongles that should sort yr problem as it did for me a while back, just cant find the exact link for the life of me!!
  • geo142
    8 March 2005 at 17:51
    thanks a lot cokka will try theat
  • Frank Droog
    10 March 2005 at 20:15
    Sounds like a handshake problem but there is not enough info.
    Are you cutting to a serial port?
    Windows 2000 and XP default to a Handshake of NONE.
    I would suggest changing the Handshake of Com1 and Com2 in windows/control panel/ports/ advanced to a Handshake of either Hardware or Xon/Xoff
    With Handshake set to none, a the cutter will cut for a while, but when its Buffer is full, it will NOT tell the computer to STOP sending data while it frees up some buffer space. So the plotter will do strange things with this buffer overrun.
    Windows 3.1 / 95 / 98 default to Xon/Xoff
    hope this cures the problem for you.
    frank at cadlink
  • geo142
    11 March 2005 at 18:35
    thanks a lot frank i will try it
