Home Forums Software Discussions Corel Software can anyone give me some advise please with coreldraw?
  • can anyone give me some advise please with coreldraw?
    Posted by mike dempsey on 17 July 2007 at 10:44
    Having looked at all the posts in corel this morning (and found them very infomative as well) I am still no further forward with what I am trying to achieve.
    A customer of mine wishes me to engrave some text and a logo on some coasters for him. The logo in the centre is no problem. The text on the upper part of the coaster is in a curve near the outside edge is ok and reads the correct way. It is when I try to do the second bit of wording at the bottom bit of the coaster that I am cracking up at. The wording is in a curve but is reading upside down and I cannot get it to curve the opposite way so it reads correctly. As I have been trying for hours I am now at the point of cracking up and I am very tired due to staying up late for the last two nights to get this done. I did see a toolbar at one point which you can change the curvature of text but I cant find it as it disappeared before I could really see what it was. I have read the help files as much as possible but as I am not totally familiar with all the correct terminology I am probably looking in the wrong place.
    Any help from a knowlegable bunch of people such as yourselves would be much appreciated.
    Ps Can anyone reccommend a decent book for learning coreldraw 12?
    Hugh Potter replied 18 years, 4 months ago 4 Members · 6 Replies
  • graffica
    17 July 2007 at 11:12
    Draw a circle or oval.
    Select this and the text.
    Go to Toolbar, TEXT. Fit text to path.
    On the toolbar, you´ll see an "abc" (small letters) with a curved line above it like a smiley mouth.
    Click on.
    On the toolbar find "Place on other side" and click.
    Then "distance from path".
    Edit. Break curve apart which separates the oval from the text.
    Others who have Corel 12 might have a better way of doing it.
    Good Luck, Chris
  • Graeme Harrold
    17 July 2007 at 13:23
    I just did 200 individually named slate coasters, but used Engravelab for the entire job. I usually use Corel for all my graphics work and as yet have not engraved directly from it 1) not sure how and 2) not had the time to find out.
    The post from Graffica is the way I do it. One of the hardest concepts is working out where the text will end up, however always try to place text on the outside of the curve to avoid bunching and possible character overlap (this also applies to cutter thickness).
    All I know about Corel has been learned as I go along, through trial and error and with some guidance from the help files.
    What I can offer is help in optimising line graphics for quicker cutting i.e. getting the order right and joining objects to minimise tool lift operations.
  • mike dempsey
    17 July 2007 at 15:15
    Dear forum members
    I am a very happy person this afternoon.
    After playing about with the file this afternoon I have answered my own question successfully.
    For anyone else out there who is self taught like myself I will let you know how I did it and it is so simple that I could kick myself.
    This to write 2 pieces of text in a circle with the top part up the right way and the bottom part the right way up as well and not reading upside down
    draw circle to correct dimension
    type in text and click fit to baseline
    click pick tool
    click text (red diamond should show up)
    right click red diamond (new toolbar appears)
    click on right hand side icon (place on other edge)
    The text will move to the inside of the circle and be the right way up
    15 August 2007 at 13:06
    the other thing to consider when you ‘fit text to path’ is that the text will go along the line, in the direction you drew the line, normally never a prob as we all, i imagine draw a line from left to right, however, in the case you have here, it’s easy to simply copy / paste a curved line, flip it, and use it at the bottom, then you have probs with text being backwards etc ! to me a while to figure that one out !
  • Graeme Harrold
    15 August 2007 at 13:10
    quote Hugh Potter:
    Hugh,
    If that happens, select the "node edit tool" and right click on the offending line, then select "reverse path" hey presto the line now goes the other way…………
    15 August 2007 at 14:51
    well, i’ve just learned another thing !! cheers !
