Home Forums Software Discussions Corel Software can anyone explain how to do a turf logo in corel?
  • can anyone explain how to do a turf logo in corel?
    Posted by Kevin Parr on 6 October 2008 at 19:16
    Hello i was wondering if anyone can help me please .I have to make a turf sign and my customer wants a spiral that looks like a piece of turf but when i use the spiral tool in corel draw x4 and make it say 5mm thick when i come to cut/plot it the spiral only cuts a single line so i cant weed it.This is driving me mad i have done it before and i cant remember,hence the help
    thankyou .kevin
    Kevin Parr replied 17 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Glenn Sharp
    6 October 2008 at 19:23
    use the contour tool and then break apart, then remove the centre line 🙂
    6 October 2008 at 20:22
    hi, simply select the spiral and then click arrange> convert outline to object. job done 🙂
    6 October 2008 at 21:35
    Just a pointer, any cut line, must be a hairline, NOT a thick line,
    to check what will be cut, view the drawing in wireframe, WYSIWYG.
    saves a lot of wasted vinyl….
  • Kevin Parr
    6 October 2008 at 22:43
    Sorry for posting this as a new question (also) i pressed the wrong button.Many thanks for all your help im overwelmed by the number of you who have taken the time to answer my question.I have tried to do the above but no joy but i will start again i am missing something so simple but i suppose it the pressure of getting it done on time .What i dont understand is when i want to make a spiral and cut it 5mm thick how do i do that,because when i do use the hairline and the wireframe to view it ,when i go to cut it doesnt cut the 5mm thick line i want would you please walk me through it if poss ,sorry for being a pain
    6 October 2008 at 22:58
    step one
    draw the spiral to the desired shape and size
    sterp two
    select the outline tool and then the first flyout, the outline pen
    step three
    specify 5mm as the thickness
    step four
    do as hugh says
    convert to outline
    stepfive
    switch to wire frame, and delete the original line from the centre.you should be left with a spiral ready to cut
  • Glenn Sharp
    7 October 2008 at 07:34
    different way, same result
    1) Draw the spiral to size and shape required
    2) Select spiral and put a 2.5mm contour on it
    3) Use ‘break apart’
    4) remove original centre line
  • Kevin Parr
    7 October 2008 at 21:36
    many thanks for all your help i got there in the end
