Home Forums Vinyl Cutter Discussions Roland Cutters can anyone dvise on versacamm cutting problem please?
  • can anyone dvise on versacamm cutting problem please?
    Posted by Paul Seamer on 18 November 2007 at 20:23
    Hi Guys.
    Had my new Versacamm just over a week now and I am well chuffed with the quality. The only small problem I have is with cutting. I am printing onto vinyl, then laminating it. In total it is about 450 microns thick. I have got different blades in it, and it is cutting deep enough now. The only problem is it seems to cut upto 3mm out. When I’m doing decals it leaves a 3mm gap at the top and cuts into the decal by 3mm at the bottom. Where should I start? Was going to start with the speed of the machine?
    Any help appriciated.
    Paul
    Paul Seamer replied 18 years, 1 month ago 4 Members · 10 Replies
  • 10 Replies
  • Nick Minall
    18 November 2007 at 20:54
    have you do a test cut from the control panel ?
  • Paul Seamer
    18 November 2007 at 22:06
    I had done a test cut when I first tried it to get the depth right. Got that right for depth but printed a few meters worth off and the cut was out.
    Do I have to do test cut before every cut?
    Paul
    18 November 2007 at 22:16
    hi
    if the versa has a environment check do this first.
    as its a new machine it should have been set correctly when installed.
    if you print and cut in one operation is it satisfactory.
    if you print laminate then reload is then 3mm out.
    there are two different settings or calibrations .
    print head to cut adjustments and test calibration in main menu.
    cut head to alignment dots adjustment is in the service menu.
    all tests must be done on white vinyl
  • Paul Seamer
    18 November 2007 at 22:27
    Thanks Chris
    The guy set everything up and we did one decal and it cut perfect. Just when he went and I printed a couple of meters it was this far out. Didn’t want to touch the settings as he said I shouldn’t have to touch them and I don’t have a clue! 🙂
    Paul
    18 November 2007 at 22:29
    yes but was that test decal laminated and reloaded before cutting
  • Paul Seamer
    18 November 2007 at 22:31
    Sorry chris. Yes it was. Printed, laminate then cut. Do you think speed may play a part in it being out?
    18 November 2007 at 22:49
    they can go out now and again.
    to check before ringing your suppliers because the laminated thickness you quoted seems high.
    set up a small file 25mm square black with a cutpath.
    print and cut this out about 6 across the plotter these should cut correctly.
    print again with reg marks no cut
    reload and auto aligh to marks. then send cut path.
    if this is ok then its strugeling with the laminate if out proberbly needs adjustment
    18 November 2007 at 23:00
    further speed should be around 300 450 normal for very thick or hard laminate and when the cut pressure is above 200 slow it down to 200 and use all the pinch rollers,
    i normally only prrit and cut over a 4 ft length for multiples of stickers.
  • Gavin MacMillan
    19 November 2007 at 09:04
    I had loads of problems when I first starting cutting with the versacamm. I’ve found that the only way to get good results is to do an ‘auoto’ print and cut calibration before cutting. This prints a black square and then reads its location. I do this on almost every cut job, it’s the only way I can get the machine to cut correctly.
    Gavin
  • Paul Seamer
    19 November 2007 at 21:59
    Hi guys.
    Thanks for the help. Slowed the machine right down and it seems to be much better now. Will let you know how it goes tomorrow when I print customers work off.
    Thanks again
    Paul
