can anyone advise with laminating foamex?
does any one know where I can get 3050 (or larger) black 5mm Forex – we have a dozen 900 x1500 prints to mount to PVC for a photographic exhibition.
We’ve had sheets cut down from 3050×2050. of Non Forex PVC, but this is not sufficiently consistent in thickness, to run through the laminator – the PVC varies from 4.6 – 5.5mm in thickness, along the short side. Have tried Amari, but they don’t stock much 5mm black.
Any suggestions, or tricks for laminating to non flat PVC – we’re getting waves / bubbles 2/3rds the way in to the material. We know the rollers are good, as we have no problems running dibond / Kapa or the PVC (when run through the machine against the length). Unfortunately the Jetmounter is only 44", so can’t run the 900×1500 on the long side…
