Home Forums Vinyl Cutter Discussions Roland Cutters can anyone advise why my roland pc60 wont respond?
  • can anyone advise why my roland pc60 wont respond?
    Posted by ianh on 26 May 2007 at 15:41
    i have just upgraded to a pc 60 i had it cutting on vinyl master pro software left it came back next day and i can not do a thing with it i cant even do cut or print test help please
    ianh replied 18 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
    26 May 2007 at 15:48
    Sorry don’t know anything about these older printers but there are a few people on the boards that still use them so maybe one of them can help you.
    Just a suggestion though, if you go to the hello forum and introduce yourself then a lot more of the board members will reply to your questions, people on here are very friendly but we like to know who we are talking to.
    Good luck finding some help for your problem.
    26 May 2007 at 15:58
    hello who ever you are.
    after it has set up are there any lights flashing before you send any data
  • ianh
    26 May 2007 at 16:43
    thanks Martin will try that
  • ianh
    26 May 2007 at 16:46
    Hi Chris
    all lights on there are 2 that do flash which are the sheet type (piece and roll)
    i read in the manual that the flashing lights show the faults at least all are not flashing 5 times
    26 May 2007 at 19:22
    quote :
    means vinyl not loaded correctly or pinch rollers out of position
    with those two flashing it will do nothing
    Chris
  • ianh
    27 May 2007 at 01:52
    quote Chris Wool:
    quote :
    Chris
    chris i undestannd what your saying how do i rectify this please
    27 May 2007 at 10:12
    open the ft cover there are 4 white tape lines on the carriage cross bar the pinch rollers MUST line up under those lines.
    the right roller anywhere under the long one, the lt one under any of the others. the distance between the rollers is you printing cutting area.
    also the vinyl when loaded must cover both electronic eyes front and rear.
    Chris
  • ianh
    27 May 2007 at 10:47
    Chris
    Thankyou very much i just hope one day i may be of help to you can’t help thinking this wont be the last time we speak
    once again many thanks
